  1. Canadian border VT
    Heading out for my daughter’s chorus Christmas concert:D
  2. Chazsbetterhalf
    Chazsbetterhalf
  3. Canadian border VT
    I will I’m just very thankful my daughter has her mothers looks and voice :D
  4. rottiman
    So are we..................................:rofl: :lol::thumbs:
  5. Marshel54
    Marshel54
    Times sure are a changing. You, wildwest and many others have talked about attending a Christmas Concert on Sunday. They are doing it here also.
    Back in the olden days, when the dinosaurs still roamed the earth as my grandson once say, store weren't even open on Sunday. If you didn't get what you needed on Saturday, good luck on buying it on Sunday.
    Parents would of raised the devil about a school function on Sunday. Many parents wouldn't have let their kids attend.
  6. Horkn
    Unfortunately there's some idiots that don't heed this advice. That Mormon family that was ambushed and killed had previously had involvement with a cartel. Originally it was thought that this ambush was a case of mistaken identity, but as it turns out, that wasn't the case.
  7. Horkn
    I've been to quite a few counties and far away places, and that still isn't enough.
  8. rottiman
    I have a simpler solution............... my solution has no list of ""Don'ts" and only one "Do".....................Do stay out of a "Chit hole" country full of guns, gangs and a government that is more corrupt than the cartels............................ :thumbs:
  9. Horkn
    That applies to Chicago, right?
  10. rottiman
    and the list goes on and on..........................
  11. ole
    ole
    Rock County Wisconsin
    A rookie mistake was made by me this morning yet I am not a rookie. The ashes had built up pretty good in my Drolet so I let the fire go out last night and gave it a good cleaning early this morning. Dumped the ash box outside in the field behind my shed and got to building a new fire. Four cherry splits on the bottom and 5 mini splits of really dry oak kindling on top of that, 4 newspaper knots and away we go. She got raging faster than normal turned the air down and REALIZED I had neglected to put the little cast iron door that covers the hole that allows the ashes to drop in the pan! Had a pretty good inferno going even with the damper on the stove pipe shut down as well. Stovepipe thermometer maxed out at 500F and stovetop temp maxed out at 750 F. 45 minutes later all the drama was done. No harm no foul because it was such a small fire but she was a roaring!
  12. ole
    ole
    I will ask the experts here for some advice. If I would have had the firebox stuffed full to the burn tubes what should I have done with a runaway? It would have taken more than 45 minutes to burn all that fuel down?
  13. Horkn
    Could you block the intake area with some non flammable item?
  14. ole
    ole
    ^^ That thought did cross my my mind briefly. I have some flat stock out in the shed that would have worked. I did temporarily put some duct tape around the edges where the ash pan slides into the pedestal base and that really slowed the fire down,,
  15. rottiman
    Open the door wide and let er' burn like a camp fire, that should wind down the run away fire.....................
  16. savemoney
  17. yooperdave
    I have heard this also. Never had to try it thankfully, but makes sense.
  18. wheelhorseiron
    wheelhorseiron
    Arkansas
    By no means an expert, but grandma told be to throw all the ashes you can on the fire.
  19. yooperdave
    Stand by for smoke!
  20. Marvin
    Marvin
    Huntingdon, Pa
    That is every fire for me except I have double wall pipe so its pushing 1000* instead of 500*...
