Passive heat movement
Discussion in 'Everything Else (off topic)' started by Marvin, Nov 28, 2019.
  1. Marvin
    Marvin
    Huntingdon, Pa
    I'm thinking of cutting some wall vents to help heat move from room to room (see pic). Eventually this gaping hole in the wall will be closed off and a door will be cut in to the wall at the top of the steps from the basement. Good idea or bad idea? I'm assuming I would need cold air vents in the floor...
  2. Chaz
    Chaz
    Southwestern NY
    Is the stove located in the basement?
    Just remember that it's easier to move cold air than hot air.
  3. rottiman
    What size bar on the saw?????.........................:rofl: :lol:
  4. Marvin
    Marvin
    Huntingdon, Pa
    Yeah the stove is in the basement. The heat comes up the steps but some of it seems to get caught on the ceiling of the pictures room. It's always about 5-10* warmer in there than the adjacent room. I tried the fan on the floor with little luck.
  5. Marvin
    Marvin
    Huntingdon, Pa
    36" :rofl: :lol:
  6. billb3
    Just make the doorway bigger ?
    Or, sliding doors for your new openings:
    Might not be room on the right due to the sloping ceiling. Sliding doors come in varying widths.
    There are quite a few ways to open up walls. Load-bearing walls can be tricky.
  7. bushpilot
    bushpilot
    Eastern Washington
    I am not sure the vents would help, but I believe a ceiling fan would.
  8. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Maybe start with the floor vents to get the air circulating?
  9. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Was the fan on the floor of the cold, or warm room?
  10. savemoney
    which way did you have the fan headed? If you want a floor fan to work, you have to pull the cold air off the floor of the cooler area and blow it towards to source of the heat. The warm air will automatically back fill the cooler room. As that air cools it will drop to the floor and be pulled out by the fan, pushed towards the heat for reheating and so on. Ceiling fans on winter mode are the best for keeping a room evenly heated. I had one at the top of the stairs. The did the most for circulating heat without the draft of a fan blowing. Cutting vents in walls or ceiling is touchy esp. with insurance. You have to have duct work connecting both sides of the openings.
  11. In the Pines
    In the Pines
    floor vents will help the cold air sink and allow the hot air to rise. I plan on doing this to a 2 story house I'm working on.
    They won't necessarily allow the hot air up thru the vent but it will get air moving passively. At least that is what I am lead to believe.
    Oh an any holes you create need some form of firestop.
    They make vents with a "fuse" so the vent door will slam shut if the temperature rises
    above that threshold to prevents flames from spreading faster.
  12. Eric VW
    Our form of fire stop was to build a “chase” or duct from the floor vent down to within 6-8” of the basement slab. The cold air blanket on the main floor has an easier time dropping down as opposed to using the stairwell to move both warm and cool air.
  13. Backwoods Savage
    Always check with fire codes before cutting holes in walls or ceilings.
    savemoney, Chaz, brenndatomu and 5 others like this.
  14. rottiman
    Not to forget the wife also..........................:rofl: :lol:
    yooperdave, savemoney, Chaz and 10 others like this.
  15. Canadian border VT
    My house design is great at air movement, raised ranch style stairs center of house, sloped ceilings. Interested to see what works for you.
  16. Marvin
    Marvin
    Huntingdon, Pa
    My plan is to put in a split door similar to the one pictured so I can open the top but keep the stairs blocked off. Little ones and stairs dont seem to mix from my understanding.
  17. Marvin
    Marvin
    Huntingdon, Pa
    I had the fan on the floor of the colder room blowing toward the warmer room.
  18. Marvin
    Marvin
    Huntingdon, Pa
    It was blowing toward the basement steps. I suppose I could try installing a ceiling fan in the room with the basement steps. There is one already installed in the cooler room that is set on winter mode.
  19. Marvin
    Marvin
    Huntingdon, Pa
    I plan to use those if I end up cutting holes :yes:
  20. Marvin
    Marvin
    Huntingdon, Pa
    Good reminder. Thank you!
