What blast media is good for cleaning Harman fire Bricks?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Nov 25, 2019.
  1. don2222
    don2222
    Salem NH
    Hello
    Trying to figure out what works best without being to abrasive?
    I just started out low with ARMEX soda blast media with a really black sooty brick. I cleaned the top edge. Is another media better?
    Pic 1 - Before
    Pic 2 - After
    Pic 3 - Soda Blast Media
    video of soda blasting
  2. Lousyweather
    Lousyweather
    Ive lightly wire brushed mine, but you should be able to pick up split 1" fire bricks pretty cheaply locally for 3-4 bucks each
  3. don2222
    don2222
    Salem NH
    Hello
    Yes those bricks are common and easy to buy new ones but I need to pay for my blasting cabinet somehow?
    So cleaning them and also blasting designs and then filling the etchings with black paint may be a whole new product for Harman stoves.!
    How does this idea look?
    BTW
    I started low on the hardness scale with soda blasting a firebrick that was black with soot! It did not seem to get all the Black off, it may have been ok if the brick was just brown. I just got some walnut shells which is about 4 on the hardness scale and will try that next. :)
  4. Rona
    Rona
    southwestern Minn
    Menards carries them cheap or try taking them to car wash.
    imacman and don2222 like this.
  5. Pete Zahria
    Pete Zahria
    New Hampster
    Brand spankin' new... 3 for 10 bucks at Lowe's.......
    But a bigger question for me is..
    Why do you need to even clean them?
    What are you burning?
    These are 4 years old..
    I just vac the ash off when I clean the stove occasionally.
    Of course if yours are a lot older, that would explain it...
    :emb:
    Dan
    bert the turtle and subsailor like this.
  6. don2222
    don2222
    Salem NH
    Waste time going to the store and buying more bricks? This is quick and very easy if you have this handy tool?
    Looks like the winner is crystal clear in the Fire Brick Cleansing Program!
    White Aluminum Oxide took it all Off!
  7. Pete Zahria
    Pete Zahria
    New Hampster
    You may be right.. a couple grand for a blast cabinet,
    and I can save that 10 bucks every 8 or 10 years..
    :makeitrain"
    Earl764 and don2222 like this.
  8. don2222
    don2222
    Salem NH
    LOL - The one I have is only $1300 new.
    I got this off CL for $150 so now if I can do some jobs with it, maybe some day it will pay off?? :)
    Harbor Freight has them for approx $150 brand new!
    Here is one on eBay for $100 and you can get a table top one used for $35 so you do not have to spend a lot. :)
  9. Pete Zahria
    Pete Zahria
    New Hampster
    Or..... I can spend 10, and get brand spankin new ones..
    and they will probly be there when I kick the bucket..
    :yes:
    subsailor, imacman and don2222 like this.
  10. badbob
    badbob
    Um,Why? Scrape and reinstall. Sorry I did not read the whole thread,because there was no reason to.
    subsailor likes this.
  11. don2222
    don2222
    Salem NH
    See first pic! That fire brick was black as night!
    Granted my firebricks and most firebricks are not nearly that bad, but since this method works the best the bricks will come out cleaner and not have that shelf line down the bottom.
    Also gives me something to do with the cabinet :)
  12. Pete Zahria
    Pete Zahria
    New Hampster
    The "REAL" reason....
    :yes:
    Dan
  13. bert the turtle
    bert the turtle
    Any soot I've had burns off with a sufficiently hot fire.
    I just had some soot on my glass this evening from a log that slid forward. I turned up the stove to full blast and it evaporated quite quickly.
    Maybe I just burn hotter than I should. That would explain the warped baffle plate. But it does clean the bricks!
    Pete Zahria and imacman like this.
