Tamarack 1/2 dry. VS. wet Oak.
Discussion in 'The Wood Pile' started by Heat550, Nov 21, 2019.
  1. Heat550
    Heat550
    Minnesota
    Witch one would you get most BTUs ??
    My guess is the tamarack ? Any advise ?
    Sent from my LGL84VL using Tapatalk
    metalcuttr, Horkn and Chazsbetterhalf like this.
  2. stuckinthemuck
    stuckinthemuck
    Do you have a moisture meter reading for each? That would be a good place to start so you know the percentage of BTUs that will be used solely for evaporating water before the wood burns... only advice I have is to store the wood inside until it is burned.. as the temp gets colder, the average indoor humidity will decrease... also make smaller splits so the wood gives up its moisture more quickly.
  3. Heat550
    Heat550
    Minnesota
    I know I got meter I need to check it before purchase. And it will get packed in a wood shed .
    metalcuttr likes this.
  4. stuckinthemuck
    stuckinthemuck
    When do you plan to burn it?
  5. Paul bunion
    Paul bunion
    If the oak is direct from the stump green it will be about 80%. The larch is probably going to have less moisture.
    But if you find that the wood is still too wet to burn and you need to wait till next year on it you are better off with the oak. If that makes any sense.
  6. Heat550
    Heat550
    Minnesota
    I need to burn it this year . I burn about 15 cord average couple houses and shop and garage.
    stuckinthemuck and metalcuttr like this.
  7. metalcuttr
    metalcuttr
    western WA
    Split you Larch small and I suspect it will burn better than the oak no matter what you do to it!
    stuckinthemuck and Midwinter like this.
  8. stuckinthemuck
    stuckinthemuck
    After you split it small, get as much as possible stacked inside in a heated space and take advantage of low humidity.
