Quadrafire Ignitor trouble
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Marshal, Nov 19, 2019.
  1. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
  2. Marshal
    Marshal
    Minnesota
    Well I replaced the tc and the stove will do a start up. After the start up it doesn’t continue feeding pellets. Now what?
    imacman and slvrblkk like this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    Are you getting enough pellets in the initial pellet dump to heat up the TC?
    imacman likes this.
  4. Marshal
    Marshal
    Minnesota
    Seem to be. Maybe I need to adjust the tc more get it out over the pot more?
    Russell, imacman and slvrblkk like this.
  5. Marshal
    Marshal
    Minnesota
    It starts up and never continues to dump pellets. It goes out after a while and shuts down.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    How large is the fire in the pot? For testing purposes you can open the feed gate up all the way
    imacman likes this.
  7. Marshal
    Marshal
    Minnesota
    I added some pellets before the initial start up to see if that would help and it still doesn’t want to keep feeding after start up.
    slvrblkk likes this.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    Do any lights come on the control box during startup?
    imacman likes this.
  9. Marshal
    Marshal
    Minnesota
    I will see. I ran back home to get the new board to see if that makes a difference. I put the old one back in it.
  10. Marshal
    Marshal
    Minnesota
    With the new board in it will do a start up then it flashed yellow then shut down. Then the thermostat calls for heat so it will fire up again.
  11. slvrblkk
    slvrblkk
    Northampton, PA
    Yellow/amber is thermocouple... Just making sure but you did put the new yellow and red thermocouple wires back in the correct orientation on the terminal block?
    imacman and kappel15 like this.
  12. Marshal
    Marshal
    Minnesota
    I believe so
    imacman likes this.
  13. Marshal
    Marshal
    Minnesota
    I just tried it without being hooked to a thermostat and it did it’s start up and quit dropping pellets. No lights and it is still running and the room fan is still going.
    imacman likes this.
  14. Marshal
    Marshal
    Minnesota
    So basically it’s not calling for more heat. It’s doing a start up and then it never starts feeding pellets with the new or old board in. Is there a heat switch that my be bad?
    imacman likes this.
  15. kappel15
    kappel15
    Sorry to jump in here slvrbikk, but not being hooked to thermostat or thermocouple? If thermocouple, it's same thing as if the tc was bad. Either tc is bad, or not sticking in pot at least 3/4" and touching the inside end of the cover, to read temps correctly. kap
  16. slvrblkk
    slvrblkk
    Northampton, PA
    The more the merrier!
    imacman likes this.
  17. slvrblkk
    slvrblkk
    Northampton, PA
    Or you have a broken/frayed thermocouple wire on the stove wiring harness possibly???
    imacman likes this.
  18. Marshal
    Marshal
    Minnesota
    I unhooked it from the wall thermostat and jumped it where the thermostat hooks up to see what it would do. The thermocouple is brand new and has the porcelain cover on and is pushed over the burn pot an inch or so.
    imacman likes this.
  19. slvrblkk
    slvrblkk
    Northampton, PA
    Can you time it and see how long, on startup, the pellets feed? Should be 98 seconds ish.......
    imacman likes this.
  20. Marshal
    Marshal
    Minnesota
    First off before I do that I want to say thank you to you and others for the help.
