Ash in Stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by Russellmania, Nov 19, 2019.
  1. Russellmania
    Russellmania
    plaistow, nh
    I was wondering if there are any advantages to keeping a little bit of ash in the stove from previous burns or if it is best to clean out the whole stove while emptying a full ash bin.
  2. brenndatomu
    Hi Russ...yup, that's what I do...seems to hold hot coals better/longer that way.
  3. papadave
    Hey Russellmania , welcome aboard.
    I've read some owners manuals that say to leave a bit of ash in the stove. Like brenndatomu said, they tend to hold coals for a while.
  4. Russellmania
    Russellmania
    plaistow, nh
    Thats good stuff, thank you for the responses
  5. papadave
    You betcha.
    I emptied most of the ash last night, but left about an inch before making a new fire. Cold stove, so no coals.
  6. bushpilot
    bushpilot
    Eastern Washington
    Englander recommends leaving 1" of ash in the stove when cleaning it out.
  7. papadave
    I knew I'd seen it somewhere. :whistle:
  8. bushpilot
    bushpilot
    Eastern Washington
    Yeah, that pesky stove manual ...
    A story, recently our dog had to go to the vet, and was prescribed a medication. After I got home, I read the brochure that comes with the medicine, and found that the prescribed dose method (involving splitting a larger pill in two) was expressly forbidden by the drug company, as they did not guarantee a consistent dosage that way.
    So back to the vet, and I explained the problem to the tech. A few minutes later, the vet came out, embarassed, and fixed the problem. "Who reads those things anyway?!" she says.
    Well, I usually do ... :picard:
  9. papadave
    Same here.
    Horkn, Backwoods Savage and FatBoy85 like this.
  10. MikeInMa
    I have a stove with a grate in the bottom of the firebox, through which ashes drop through into an ash try.
    Why would I want to keep any ashes above the grate?
    Off to look for the owners manual.
    *edit - owner's manual makes no mention of leaving/removing ash in the firebox. Only to check the ash tray for emptying.
  11. FatBoy85
    FatBoy85
    Washington State
    In a fireplace, I used to clean out the ashes for family, my grandmother and parents usually before burning. My grandma cautioned me to leave a little ash on the bottom so that the fire would burn better or start better.
    I believe this has some credibility to it as ash is a good insulator and reflector. Lighting on bare ground that hasn’t been burned on is harder to get going it seems somewhat.
  12. MikeInMa
    In the fireplace, were the logs in a log rack, or directly on the bottom of the fireplace, resting on a layer of ash ?
    If no log rack, then I can see where having some ash, under the to-be-litable fire, as there would be an amount of airflow to the fire.
  13. Russellmania
    Russellmania
    plaistow, nh
    I have tried both this week and when I had a little bit of ash on the bottom it did definitely start quicker and hotter than starting it with on the cold grate. I too have a grate where the ash drops down so I do the best I can.
    T.Jeff Veal and Horkn like this.
  14. NVhunter
    NVhunter
    Northern Nevada
    I've read that leaving a little ash will prolong the life of your fire brick too...
  15. rdust
    rdust
    SE, Michigan
    My stove has a deep belly(4 or 5 inches below the door). When it’s up to the door or I need room to load more wood I empty ash. It’s not uncommon to pull 5 gallons of ash out when I clean it. :loco: :crazy:
  16. Aje1967
    Aje1967
    Kenosha, Wisconsin
    Backwoodsavage says leave an inch or so and even let it fill farther. He has a wood burning primer under resources that all should read.
