Quadrafire Ignitor trouble
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Marshal, Nov 19, 2019.
  1. Marshal
    Marshal
    Minnesota
    I have a quadrafire 1200 that stoped lighting. I replaced with a new Ignitor and the new Ignitor does not get hot. Can anyone help?
    ivanhoe likes this.
  2. imacman
    imacman
    Denver, NC
    Have you checked the original ignitor w/ 120 volts to see if it's getting hot? Might not be the ignitor....could be a fuse in the ignitor circuit.
    Member slvrblkk has refurbed a lot of these and is our resident pellet stove monkey and Quad expert.....hopefully he'll chime in soon.
    ivanhoe likes this.
  3. Marshal
    Marshal
    Minnesota
    No I haven’t, last year the stove had trouble lighting. This year it wouldn’t light at all so I ordered a new Ignitor and replaced it. I watched it go threw a start process and noticed it was not getting hot. I know of one fuse that’s next to the mane board and that fuse is ok.
    ivanhoe and imacman like this.
  4. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Could be a couple things.
    The thermocouple (Unit that projects into the fire pot over the top of the flame)
    Control box
    Also check the wires that feed the igniter to make sure they are not broken where they connect to the controller.
    CAUTION HIGH VOLTAGE...UNPLUG UNIT BEFORE SNOOPING INSIDE
  5. Marshal
    Marshal
    Minnesota
    I will order a new thermocouple. Thanks for the help. I will keep you guys posted.
    Russell and ivanhoe like this.
  6. kappel15
    kappel15
    You should of tested that tc before ordering one, to see if it was good or not, as it could be something else. kap
  7. slvrblkk
    slvrblkk
    Northampton, PA
    OK, let's start from the beginning... Do the pellets smoke at all during startup?
    If not, are you handy with a multi meter?
    ivanhoe, PelletHound and imacman like this.
  8. Marshal
    Marshal
    Minnesota
    No the pellets don’t smoke. The Ignitor doesn’t get hot at all. After inspecting the thermocouple I see there is a broken wire.
  9. Marshal
    Marshal
    Minnesota
    As far as the multimeter I don’t own one. In two days I will thanks to amazon. I did figure out that the thermocouple is broke.
  10. slvrblkk
    slvrblkk
    Northampton, PA
    When you turn the stove on, is the control box flashing amber?
  11. Marshal
    Marshal
    Minnesota
    When I do a start up it will let pellets drop twice then it stops and a light comes on in the control box it is continuously flashing 3 times.
    ivanhoe, slvrblkk and imacman like this.
  12. Marshal
    Marshal
    Minnesota
    I should also tell you I have a newer control box that is clear and is on setting 2.
  13. slvrblkk
    slvrblkk
    Northampton, PA
    Normal setting is #1........you're on a +10% setting (#2)
  14. slvrblkk
    slvrblkk
    Northampton, PA
    What color is the light flashing?
    Russell, imacman and ivanhoe like this.
  15. Marshal
    Marshal
    Minnesota
    That’s a tuff one for me since I’m color blind. I believe it’s red. Here’s the culprit.
  16. kappel15
    kappel15
    Are you using a cover on that tc ?
  17. Marshal
    Marshal
    Minnesota
    Yes sir! Just removed it for the picture.
    Russell, slvrblkk and imacman like this.
  18. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    There certainly needs to be a ceramic cover that slips over the wire and protects it
    There should be a small metal bracket that slips under the rim of the fire pot where it contacts the firebox floor, and the little ceramic tube and TC slip into the bracket.
  19. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Good chance that when you get the fresh TC in that things will work.
    The TC sends a small current to the controller to tell it if there is fire or not.
    Keep us in the loop on how it goes after you replace the TC
  20. Marshal
    Marshal
    Minnesota
    I think your right! I will let everyone know what happens. Thanks for the help fellas!
