New member saying hello
Discussion in 'The Wood Pile' started by Holland Dell, Nov 17, 2019.
  1. Maina
    Maina
    Welcome to the right place to openly discuss your addiction You’ll find lots of like minded folks here. I’m with DaveGunter on stove choice as my avatar would attest. Most functional piece of art I’ve ever owned.
    Horkn, T.Jeff Veal, Midwinter and 3 others like this.
  2. Buffalo Plaid
    Buffalo Plaid
    Pepperell, MA
    Welcome to the club Holland Dell . Good on you for getting the hoarder started before needing it. Stick around and you'll pick up all kinds of tips and a strange sense of humor too.
    Lone_Gun, Horkn, T.Jeff Veal and 2 others like this.
  3. Holland Dell
    Holland Dell
    SW Wisconsin
    No black locust in my plot that I am aware of. I'm down in the SW corner of the state. Iowa/Lafayette county.
    metalcuttr, Horkn and T.Jeff Veal like this.
  4. Holland Dell
    Holland Dell
    SW Wisconsin
    Thanks Buzz. I rigged up a couple power poles that stradle a tree. I don't have a skid steer, so figured I could winch the logs onto the poles from the tree using my UTV winch with a block and tackle set up. I have several nice cherry, walnut and ash logs bucked to 9 feet. Do I need to seal the ends with something? 20191117_115939.jpg 20191024_150922.jpg
    Marvin, Thor, Lone_Gun and 4 others like this.
  5. MikeInMa
    I had a bunch of red oak rounds stacked on some saplings, uncovered. 18 months later they split just fine, with no rot. So long as you can get them off direct ground contact, they'll be fine.
  6. T.Jeff Veal
    Yes sir, if you are planning to saw these logs into boards, then the ends need to be sealed, with paint or sealer. It will help to prevent cracking.
    Horkn likes this.
  7. GrJfer
    GrJfer
    The Woods of Arkansas
    Holland Dell welcome to the land of BTU's. Glad to have you join us. Sounds like you have a nice jump on your future wood burning. What saw are you using?
    T.Jeff Veal and Horkn like this.
  8. buZZsaw BRAD
    If its for firewood use no sealing. Not sure sealing needed if its to be milled into lumber.
    T.Jeff Veal and Stoveaclaus like this.
  9. Erik B
    Erik B
    Western Wisconsin
    Welcome Holland Dell You found a great place to get answers about everything woody and to help others with their concerns. I am up in La Crosse county just north of you a bit.
    metalcuttr and T.Jeff Veal like this.
  10. T.Jeff Veal
    Unless it will be milled quick, ends need to be sealed to prevent checking on the ends
  11. Stoveaclaus
    Stoveaclaus
    Long Island, NY
    As a woodshop teacher I can tell you how frustrating it is to lose 6” off of each end from checking.
  12. Holland Dell
    Holland Dell
    SW Wisconsin
    Stihl MS271, Stihl MS193C and a Milwaukee Pole Saw for shaping walnuts for future veneer logs.
    metalcuttr, GrJfer and T.Jeff Veal like this.
  13. Holland Dell
    Holland Dell
    SW Wisconsin
    Thanks folks. I better get them sealed up quick. I have a local mill that wants some of them, but they tend to be a little slow at picking them up. Worst case scenario if they don't get picked up is selling them to the local craftsmen. We have an abundance of artist in the area that need blanks. The Walnut logs are all veneer quality and should be gone in a few weeks. I also found several people that want "decorative" firewood for non-functioning fireplaces. They really like uniform pieces of cherry and walnut. The next research project is drying Basswood blanks for carvers. Other than burning and lumber, is Ash good for anything?
  14. moresnow
    moresnow
    If speaking to a home insurance agent about wood stoves. Be sure to tell them it is supplemental heat only. They may have a fit if you call it primary. Something to consider in todays world. Basically play there game!
  15. Canadian border VT
    Base ball bats
  16. Holland Dell
    Holland Dell
    SW Wisconsin
    Thanks YooperDave. Sorry for the delay getting back to you. I am about 1.25 hours southwest of Wisconsin Dells. My family has several recreational and rental properties in the Eagle River and Rhinelander area. A little closer to your southern boarder.
  17. yooperdave
    I drive through there frequently on my "Menards run".
    I'll keep the rentals in mind as every now and then someone asks about a cabin for a week. Well, first I should ask if the above mentioned properties are short or long term rentals?
    T.Jeff Veal likes this.
  18. Holland Dell
    Holland Dell
    SW Wisconsin
    They are all long term, full year leases.
    T.Jeff Veal and yooperdave like this.
  19. Marvin
    Marvin
    Huntingdon, Pa
    Welcome to the club Holland Dell! Dont be afraid of sharing pics as you progress! Pics are always a good thing here :yes:
  20. leoht
    leoht
    Victoria. Australia. Earth.
