Crazy brain droppings
Discussion in 'Chainsaws and Power Equipment' started by jo191145, Nov 12, 2019.
  1. jo191145
    A little tribute to Carlin ;)
    Crazy idea here. Anyone ever rig up a screw splitter to an ice auger?
    I’ve never used an ice auger. I assume it takes a bit of force to drill a big hole through ice.
    Never used a screw splitter. I’ve had one for about five years I once dreamed of attaching to my tractor. Never did.
    Just wondering if anyone ever tried it?
  2. Ronaldo
    Ronaldo
    An ice auger actually shaves as it goes and therefore doesn't require a whole lot of power. Splitting with an auger/ screw type attachment would need much more power.
    Chaz, jo191145, XXL and 2 others like this.
  3. jo191145
    Well, all drills shave as they go. Otherwise it would be a punch LOL
    Anyone who’s chipped ice knows it’s not that easy. Shaving isn’t much different.
    Gas Post hole diggers dig through dirt. Some dirt easier than others for sure.
    I was thinking it may be useful for knocking apart large rounds. Screwed into the butt of the round, not the side as some do. Red oak at that, not hickory. Oak pops pretty easy unless it’s got lots of knots.
    The screw I have is fairly fine threaded. I also get the impression from it that weight behind it is important.
    It’s quite possible I’m way off base here. Someday I’ll have to take it outside and play with it a bit. Maybe 1/2” breaker bar. Maybe the old 50’s 1/2” drill I have. That old beast can tear a man in half. Not saying either of them are viable but they should give an idea on how much effort it takes.
    brenndatomu and Chaz like this.
  4. Ronaldo
    Ronaldo
    True, all drills shave. If you are drilling through the wood you would be shaving material off, if you are trying to split it by screwing a wedge in, that is totally different.
    jo191145 and brenndatomu like this.
  5. OhioStihl
    OhioStihl
    Southern Ohio
    This post reminds me of the time I helped a friend use a gas powered post hole digger. It would hit some roots and we would go for a spin. We figured out technique real quick
    Ronaldo, jo191145 and brenndatomu like this.
  6. jo191145
    yeah my brother in law is a fence guy in another state. He’s not a fan of gas powered hand held augers in New England. Too many stone potato’s.
    Ronaldo likes this.
  7. jo191145
    This is the bad boy. Went and dug it out. It comes off a dingo. My BIL’s dingo. Never saw him use it. He said it’s too slow. Course he doesn’t split wood anyway. Burns old fences or nothing at all.
    A post hole digger for the JD would be better I’m sure. I wonder if a lawn tractor transmission would be good? Different speeds possible as long as you get things spinning in the correct direction.
    Midwinter, eatonpcat and Ronaldo like this.
  8. chainsawsoldier
    chainsawsoldier
    NE Kansas
    I’ve seen them on post augers before. You want a hydraulic one so you can reverse it, otherwise you will want a big pipe wrench and a cheater to back it out when it gets stuck. I know that’s why grandpa got rid of the one he used when I was a kid... hydraulic augers were not common or cheap...
    Midwinter and jo191145 like this.
  9. jo191145
    what type of post augers have you seen them on? Tractor or handheld?
    Yes I can imagine getting one stuck would be a real pain. Sinking one into gnarly wood may not be a good idea unless your fully set up to deal with it.
    My JD MT doesn’t have normal hydraulic lines one can connect to. Are most tractor hydro systems reversible?
    To be honest I don’t need it. I like building experimental things (cheaply). Always interesting to see how far my imagination is off from reality. The cheap part may be genetic but it’s part of the game. Sure I could buy a mini excavator to spin this screw but there’s no challenge in that.
    Sandhillbilly likes this.
  10. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    On a mini ex ?...... now that could prove to be quite handy
    jo191145 likes this.
  11. jo191145
    All sorts of wood porn for ya here. The screws really don’t seem the best way to go. If I had a mini ex I’d put a sharpened thumb on it. Cheaper and faster.
  12. chainsawsoldier
    chainsawsoldier
    NE Kansas
    I have never seen one of those on a handheld auger, only on PTO or hydraulic augers. I saw one online that used an impact wrench to power it, but it was a LOT smaller than the one you have. If you would get a PTO pump for your tractor, you could run the auger with hydraulics. We used to have an 8N with a loader, and it had a PTO pump to run it.
  13. chris
    Pure death wish on using those.
  14. jo191145
    Thanks for the info. Like I said I really don’t need it. I do have a little fetish about having things that have never been used. I like to use them at least once LOL.
    After watching the video of them in action, again, years later, I’d say it’s not worth a ton of effort.
  15. jo191145
    used correctly they’re not that dangerous. Incorrectly will leave you in a world of hurt.
    BIL originally had one of those you drive the car on. Because they were relatively cheap a lot of weekend warriors bought them. Those were some of the more dangerous ones IMO and the cheap price put them easily in the hands of many people who probably shouldn’t be using them. Including my BIL ;)
