Need help - Piston stop for 2260.
Discussion in 'Chainsaws and Power Equipment' started by Osage Orange, May 29, 2014.
  1. Osage Orange
    Osage Orange
    Ordered 3/8 sprocket and 24 inch bar and chain for JRed 2260. Ordered piston stop and clutch tool at same time to help with changeover. Piston stop too big for plug hole. Any idea what Baileys stop part number will fit 2260? Tried the rope plug but cylinder rolled over which is not good. Anyone help would be appreciated.
  2. DexterDay
    I like the rope trick..
    I stuff about 2-3 ft in there. Works well. Never had one turn over.
    How much did you feed into the cylinder?
  3. NewToStihl
    NewToStihl
    Central Indiana
    Amen, rope is the way to go. I like to position the piston just to the point where the exhaust port is blocked and then stuff as much nylon rope in as I possibly can. Never had one turn over like this either.
    NH_Wood and Osage Orange like this.
  4. Osage Orange
    Osage Orange
    Thanks for the response - I was not stuffing near enough rope in - only had about an inch stuck in there. Just got it by taking your suggestion. Now I have new problem - they sent he wrong sprocket. Center is too big for 2260 splines. Will see if I can find one locally tomorrow. Don't know if Stihl has sprocket that will fit?
  5. mdavlee
    mdavlee
    A decent husky dealer will have the small spline 3/8" sprockets in stock.
    MasterMech and concretegrazer like this.
  6. nate
    nate Banned
    Palmer, AK
    I just use a 3/8" impact gun, no stop needed.
    MasterMech and mdavlee like this.
  7. HittinSteel
    HittinSteel
    Wooster, Ohio
    Make sure you get the piston to the top of the cylinder before stuffing a bunch of rope in there........ don't want it getting stuck in the exhaust port. Don't ask me how I know :whistle:
    cnice_37, Boog and mdavlee like this.
  8. cnice_37
    cnice_37
    I actually like the rope over the plastic stops.
  9. NH_Wood
    NH_Wood
    Yes - luckily I found out about getting the piston above the exhaust port before using rope while breaking down a parts saw with blown top end - had a nice chuck of rope stuck between piston/cylinder. I've been using my brass stop on saws with blown top ends since is a little quicker, and rope on saws with good top ends. I haven't tried using the plastic stops yet. Cheers!
  10. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    I use a piece of 3/8" core and sheath rope. It is very pliable and large enough to avoid entering the ports.
  11. Boog
    Boog
    Where my spirit is free
    Definitely use the rope or impact gun methods ............................... do not use a piston stop tool. I used a stop tool a bunch of times until I did this to my 460's OEM piston!
