Fan reducing
Discussion in 'The Wood Pile' started by Biddleman, Nov 10, 2019.
  1. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I have my stove's burn indicator on top center of stove (no room for one on pipe. It feeds right up chimney). Of course when I turn my fan/ blower on the reading drops. The air is forced out vents on top front of stove. Obviously turn off fan and reading goes back up.
    Sometimes the indicator drops by 100*
    Is the stove actually hotter than the indicator reads when fan is on, or is the fan reducing the stove temp that much.
    Ive been assuming the stove is still hotter than indicator.
  2. jo191145
    well I would assume the outer skin temp is dropping as seen. The inner skin and inside of stove is a different matter.
  3. bear 1998
    bear 1998
    S.C.Pa
    Good ?...:popcorn:
  4. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I’ve never been a big fan of fans.........
  5. bear 1998
    bear 1998
    S.C.Pa
    Is your stove freestanding or insert....
  6. Biddleman
    Biddleman
    Freestanding
    bear 1998 and Backwoods Savage like this.
  7. DaveGunter
    DaveGunter
    I'd say yes the stove top temp is actually higher than indicated by the thermometer with the fan on. You could verify this with an infrared thermometer as it won't be affected by the airflow and will give you an accurate STT with the fan on or off.
