How close can my wood be?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Patrick MO, Nov 9, 2019.
  1. Patrick MO
    Patrick MO
    Southwest Missouri
    How far away should I keep the wood away from the glass door on my insert? The inside of the box is 18 inches deep except in the middle where the air inlet box is.
  2. MikeInMa
    I keep wood a couple of inches away from the glass on my wood stove.
  3. Horkn
    If your firebox is 18" deep, then I'd not cut any longer than 17". Stoves seem to do best with a little gap at the front and the back.
    As long as it's not hitting the glass, you are good. That's the main point.
  4. Patrick MO
    Patrick MO
    Southwest Missouri
    Is it ok if it lays on top of the air inlet box? Or should keep it to the sides?
  5. Horkn
    That shouldn't matter, just so that the wood is clear of the door. Also, the closer you put the wood by the door, there's more chance of getting dark marks on the glass. Also, there's more chance of having ashes fall out when you open the door.
    What insert do you have?
  6. Patrick MO
    Patrick MO
    Southwest Missouri
    It's a country flame E1. We just bought the house in August and have never had a fireplace or stove in my life so I'm trying to learn all I can to do it right and efficiently. It's not our primary heat source, I'm just gonna use it to offset the cost of propane.
  7. Horkn
    Is this an EPA tube stove/ insert? Does it have a Chimney liner? I'm not familiar with this insert.
  8. Patrick MO
    Patrick MO
    Southwest Missouri
    It's a cat insert, late 90's early 2000's and it does have a liner.
    Thor, Backwoods Savage, Horkn and 4 others like this.
  9. Patrick MO
    Patrick MO
    Southwest Missouri
    The person that owned the home and had it installed was adamant about keeping paper work so I have the manual and installed receipt for it. I happened to have the same guy that installed it come clean and inspect. I asked him if for any reason I may need to buy a different insert in the near future and he said definitely not, this is good one and that the newer have a lot smaller fire boxes.
    Backwoods Savage, Horkn, Chaz and 3 others like this.
  10. Chvymn99
    Welcome to FHC Patrick MO ... 16 would be what I'd aim for.... That gives you a little wiggle room, and you aint going to miss that many BTU's....
  11. Marvin
    Marvin
    Huntingdon, Pa
    Welcome to the club Patrick MO! I agree with Chvymn99 here. Plus at 16" you can stack 3 rows deep on a 48" pallet :yes:
    Backwoods Savage, Horkn, Chaz and 2 others like this.
  12. Chaz
    Chaz
    Southwestern NY
    Welcome aboard Patrick MO
    :handshake:
    Nice insert.
    Make sure your wood is properly dried.
    :yes:
  13. Mwalsh9152
    Mwalsh9152
    Pelham NH
    yeah, what he said. Just make sure you dont accidentally close the door on your wood.
  14. billb3
    Sounds like you should be cutting at 16/17 so that a couple pieces cut a tiny bit long or crooked will be NBFD.
    As long as you're not closing the door on an oddball long piece that shouldn't be a problem, you just wouldn't want them all to be that long as that is begging for a slip up.
    I have a gauge on the wood bin and wood rack to test anything that looks a bit long.
    I also have to sort shorter pieces out for one stove that the max is 16" ( more like 16-1/2")
    I was cutting with a group so we've had a lot of variance in split length.
    When you're cutting in bulk with a lot of people you don't nit pick, you work with what you've got.
  15. Horkn
    That's a general rule of life.
  16. Horkn
    Don't click here. Seriously
  17. billb3
    Yeah, wood gawd appears to be a troll
    3 posts all hawking the same whatever-it -is.
  18. Horkn
    I reported the post. Moderating
    yooperdave, bear 1998 and Chvymn99 like this.
  19. Well Seasoned
    He was being very un-gawdly and this site has been cleansed of him. Unless of course he reincarnates as another user.
