Got a loader tractor
Discussion in 'The Wood Pile' started by Firewood Bandit, Oct 12, 2019.
  1. Firewood Bandit
    Firewood Bandit
    I needed this for my apple orchard to run an air blast sprayer. Got a gently used Case IH DX33 with 398 hours on it.
    The sprayer it needs to run.
  2. Locust Post
    Looks good bandit
  3. Woodwhore
    Woodwhore
    Mason NH
    Im jealous, that should serve you well.
  4. Gasifier
    Nice!:thumbs: That will be handy for many task. Congrats on the new work horse.
  5. Steven Corio
    Steven Corio
    Missouri
    Great tractor! I have the same tractor in blue clothes with over 4600 hours on it. That tractor should last awhile!:dex:
    Is it a hydro or gear?
  6. Chaz
    Chaz
    Southwestern NY
    Nice addition to the stable.
    :tractor:
    :banana::rootintootin:
  7. billb3
    It looks fairly clean.
    Horkn, Chvymn99, bear 1998 and 2 others like this.
  8. Canadian border VT
  9. Yawner
    Yawner
    Louisiana
    I would love to have that tractor, cool! But I'd have to have tires with more grip, for sure, for the woods.
  10. amateur cutter
    Looks very nice! You'll be amazed at how many different tasks you'll find it helpfull with. Nice purchase!
  11. Firewood Bandit
    Firewood Bandit
    Hydro,
    I know the turf tires most would not like for loader work, but for me the turf tires are important in the orchard to not tear up grass and make ruts.
  12. Firewood Bandit
    Firewood Bandit
    I understand, but it is for orchard work primarily and not tearing up grass is pretty important. If a machine makes ruts in the rows between the trees, it would hold water and make it worse every time it is driven to do normal work.
    This shows the layout better, the pics are a couple years old and the trees are much bigger now. The first 4 pics are from right to left so you can see the layout better. DSCF0007.JPG DSCF0008.JPG DSCF0009.JPG DSCF0010.JPG DSCF0001.JPG DSCF0002.JPG DSCF0003.JPG DSCF0004.JPG
  13. billb3
    I have turfs on a 5 to 10 HP smaller JD.
    They're fine in the snow ( I don't have chains)
    They're fine for loader work.
    They've even been fine in the woods.
    My two complaints/issues with the turfs has been with their 'softness' :
    I've gotten a few cuts in sidewalls - probably sharp branches in the woods. For whatever reason - just the fronts.
    When picking up the weight limit with the loader those same front tires squish out quite flat. I'm surprised I haven't popped a tire off a rim.
    Horkn, Chaz and Steven Corio like this.
  14. Steven Corio
    Steven Corio
    Missouri
    A small loader tractor with a hydro trans is the best! No abusing clutches.
  15. Firewood Bandit
    Firewood Bandit
    Update:
    Had a firewood customer give me a hand today. The guy is a journeyman welder. I bought a Bobcat style quick attach loader bracket. The bucket had to have the brackets removed and a weld on plate installed. He showed up with a 26,000# service truck and $40,000 Lincoln diesel welder with compressor. He used an air arc to cut the brackets off, clean up and then weld on the plate. Total amount of grinding time was perhaps 5 min. Simply amazing to see a skilled professional practice his trade.
    Now the pallet forks will be easy to put on and off.
    Also got this for a firewood toter. The boys where I get my orchard supplies gave me this for nothing.
    Stlshrk, bear 1998, Horkn and 4 others like this.
  16. Chaz
    Chaz
    Southwestern NY
    Years of practice and good equipment
    :thumbs:
    They make it look easy peasy.
    Stlshrk, bear 1998, Horkn and 2 others like this.
