Husqy bar oil leaks
Discussion in 'Chainsaws and Power Equipment' started by bogydave, Oct 30, 2019.
  1. bogydave
    Any solutions to 359 leaking bar oil.
    (Prepping saw for storage)
    ...drain the when not in use??
    If I store the saw with the oil &
    gas cap side on the bottom, seems
    to leak less.
    Husqvarna’s nature I guess
    amateur cutter, M2theB, Chaz and 2 others like this.
  2. Ronaldo
    Ronaldo
    I have a jonsered 2152 that started leaking after 5 or so years. I had to replace the rubber pick up line that pulls through the oil tank/case. This fixed my leaky bar oil situation.
  3. Andyshine77
    Andyshine77
    Cincinnati, OH
    That's what I do, drain the tank. Pressure builds in the tank due to temperature changes and forces oil out. Pretty much every saw I've ever owned leaked some bar oil.
  4. Flamestead
    Flamestead
    Windsor County, VT
    I’m glad you ask these 359 questions because you ask the same ones I have but am too lazy to address. My 359 has gone for many years as a pretty dry saw in storage, but no longer so. Something had worn or weakened to allow an irritating amount of bar oil to weep. It would be nice to get it back to where it used to be.
  5. MrWhoopee
    MrWhoopee
    Shingletown, CA
    My Redmax G5300 (Husqvarna E353) does the same thing. It lives in a clamshell plastic case which contains the mess until I'm out in the woods where I can drain it. All 3 of my gas saws live in a case so I can carry them in a car. Keeps them from getting beat up too.
    amateur cutter, Chaz and saewoody like this.
  6. coreboy83
    coreboy83
    NW of Twin-Cities
    My 450 leaked oil like a beotch, until I turned it in for warranty. My dealer replaced it with an "upgraded" oiler. I assume it was plastic and now metal??
  7. bogydave
    So they can make a bar oiler that don’t leak?
    New Oiler leak less? But still leak?
    where to get a less leaking oiler?
    Is there an upgrade oiler by husqvarna or after market for the 359.
    If there’s a less leaking oiler , you’d think it would be required , environmentally friendly
    Regulations required less oil in the gas, but
    it’s ok to leak bar oil into the soil??
    Lol at myself
    Ranting a bit, been cleaning saw case & oil stains:hair:
  8. Ronaldo
    Ronaldo
    I think the oiler rubber pieces shrink or set up over time and just need replaced with new ones. It's not a pricey item. Look online or talk with your dealer. After replacing mine is leak free.
  9. bogydave
    thanks
    Got saw in hand
    headed to local dealer
  10. saewoody
    saewoody
    Central CT
    Mine too. Was always impressed that it didn’t leak bar oil because all others saws I had ever seen did. But it started leaking this past spring. I was also too lazy to deal with it.
    amateur cutter, M2theB and Chaz like this.
  11. bogydave
    Place no longer deals with husqvarna .
    Guess I’ll look online
    Any recommend sites for Husqy parts?
  12. M2theB
    M2theB
    Central Massachusetts
    saewoody, amateur cutter and Ronaldo like this.
  13. bogydave
    THANK YOU
    AWESOME !!!!!
    Seems its a common problem & a simple fix. :saw:
    Superglue :)
    amateur cutter and M2theB like this.
  14. bogydave
    To the pump
    Pretty dirty :
  15. bogydave
    Didn’t work for me.
    Where it goes thru the case to the tank
    is real loose. Definitely a leak spot.
    I’ll order both parts ,
    from tank & to the bar
    M2theB, Ronaldo, huskihl and 3 others like this.
  16. The Wood Wolverine
    I’ve dealt with this weep on my 357. Twice I pulled the rubber lines and cleaned them and their mating surfaces. Applied a good rtv sealeant (sparingly) and it worked for a while. I eventually replaced those lines with new OEM and it’s been leak-free since. I chalk it up to a maint. item. After so many years I’ll just throw new lines in there to prevent it from now on.
  17. huskihl
    huskihl
    I think the rubber gets soft and no longer makes a tight seal after awhile. I’d replace with 2 new oem rubber lines and maybe even the bar plate
    M2theB likes this.
  18. bogydave
    Found an online place that ship too Alaska.
    ereplacement parts
    Any reviews ?
    the 2 oil pup hoses
    needle bearing (since I'm in there)
    Air filter
    the 2 bar clamp plates.
    $70
    $5.50 shipping, says 5 business days or so,
    Couple bucks more than Jacks small engine, but jack ships to lower 48 @ $10,
    no info on Alaska shipping
    M2theB, huskihl and Ronaldo like this.
  19. huskihl
    huskihl
    No, they’re fine.
    I’m not certain you need 2 bar plates though. Unless 1 is just a spare
  20. bogydave
    Probably wrong name , 1 each of
    , inboard bar plate covers the oiler & drive shaft, outboard bar plate on the removable bar clamp gizmo.
    Both show signs of wear.
    2010 359 epa
    huskihl likes this.
