Rebuild Train Steam engine, some new & some old parts
Discussion in 'The Wood Pile' started by bogydave, Oct 28, 2019.
  1. bogydave
    Yea
    some duck bill anchors , cable & turnbuckles
    Have to be tough metal roofing, the new stuff is thin,
    I used the duckbill anchors to tie down my greenhouse, after I lost one,
    Had to put extra glue on house shingle , got tired of replacing some every spring.
    Reinforced 12’ wide garage door panels, they
    bend (bow) when the wind gets serious.
    Had to anchor down my burn barrel last
    year, found it by the frontage road 1/4 mile away .
    60 - 70 mph wind events thru winter normal,
    40 mph winds called “breezy “, past 3 days I was out stacking in 35 mph with 45 mph gusts, breezy day :D
  2. Horkn
    Well, the indiginous people made canoes with birch bark. That stuff is waterproof.
    To be honest, I don't put much into the thought of bark up or down, but on birch I sure do.
    I might be processing some in the near future, so I'll have to remember this again.
  3. bogydave
    Typically it goes to the wood shed after 1o months ,
    To the shed in August, just before the
    rainy season starts.
    I don’t know how long it would last if not top covered , bark up or down,
    Maybe a time trial test with my uglies :zip:
  4. buZZsaw BRAD
    Isnt the "smokestack" already going through the test?
  5. Backwoods Savage
    The point I was trying to make is that the bark separates from the wood much easier on birch than on most wood. That is, when you stack it, the bark just seems to curl then peel.
  6. Horkn
    Got it. It's been a while since I processed any birch.
  7. bogydave
    yea
    Not split few years ago.
    It’s close to compost, wet & heavy,
    bark holding it together.
  8. Horkn
    Locating the correct smokestack is probably hard to find in the woods.;)
  9. dingbat
    dingbat
    Western Northern Cackalaky
    My grandma was a ball buster. When we stacked wood for her she'd make us pull it all down and restack it if she could fit a finger in between any of the splits and it wasn't all bark side up. Stacking wood today I can't figure out how we even managed to meet her standards a single time, but we did. Must have been the magic of the child's brain.
  10. bogydave
    I stack loose in the seasoning stack
    Probably not drying much today
    Dreary foggy day:
  11. buZZsaw BRAD
    does the train have its fog light on?
  12. bogydave
    Of course.......
    Northern Lights :D
  13. bogydave
  14. BigPapi
    BigPapi
    The hills of Western MA
    Looking good as always, bogydave.
    I try to stack bark down on the bottom course to keep moisture from the ground out, and bark up on the top course to shed rain and keep a flatter surface for top cover. Inside the stack, however it fits.
  15. bogydave
    Your way is probably pretty good
    The splits mid stack were/are in good shape.
    Top couple of layers, maybe I should “bark up “ it.
