How to split a log, not a round
Discussion in 'The Wood Pile' started by Yawner, Oct 31, 2019.
  1. Yawner
    Yawner
    Louisiana
    I am talking about a tree of, say, six inch DBH and, a log stem off that tree of, say, nine feet long. When I do a stack of firewood, I sometimes use small trees (saplings?) as the runners to put the first layer of wood on. I saw someone on here had done what I am talking about and I wondered how he split the stems so that the crack propagates all the way down the log. If you did this, you'd get two runners instead of one.
    farmer steve and Woodsnwoods like this.
  2. MikeInMa
    Run your chainsaw down the length of the piece, not too deep.
    Then use some splitting wedges into the groove. Keep tapping unail it splits through.
    If the grain is twisted, you might need to use the saw to go all the way through.
    Good luck!
    B.Brown likes this.
  3. Jon_E
    Jon_E
    Southwestern Vermont
    Same process splitting fence rails. Basically you start a steel wedge at one end, and get the split started, and then put hardwood or plastic wedges into the split until it separates.
    Research "rail splitting" or "riving" on Youtube.
  4. Midwinter
    Skinny log, just keep leapfrogging your wedges down the length. IMG_20170901_173221599_HDR.jpg Fat log... IMG_20190910_0631.jpg IMG_20190910_10941.jpg IMG_20190910_52910.jpg This work really well on skinny or fat red oak.
    Lone_Gun, MikeInMa, Dazza95 and 3 others like this.
  5. farmer steve
    farmer steve
    top of the hill york co. PA.
    When we split locust posts for rails we used the tip of the chainsaw to make a hole for the wedge. Pound it in till tight then move down the log a bit and repeat. The second wedge should loosen the first.
    Good quality steel wedges if you can find them.
