Quadra Fire Contour - what are we missing?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Terry Johnson, Oct 27, 2019.
  1. Terry Johnson
    Terry Johnson
    Minnesota
    When we got this Quadra fire, we plugged it in and everything worked as it should including ignition and burn. It had the vertical stack attached but Our installation called for horizontal so removed the vertical stack. We also noticed the blower motor housing was bad so replaced the blower motor. Have now placed in house and connected. When we plug in, blower kicks in and such, however red light does not come on and stove will not ignite. Suggestions? We are going to pick up a t-stat in the event that is the challenge, but wonder if we’ve missed anything else?
  2. wildwest
    How disappointing! I wonder if a connection came loose during blower replacement or moving it?
  3. slvrblkk
    slvrblkk
    Northampton, PA
    Do you currently have a stat hooked up to it?
  4. Terry Johnson
    Terry Johnson
    Minnesota
    We thought we’d checked all connections but will take another look.
  5. Terry Johnson
    Terry Johnson
    Minnesota
    We have the original. We thought that was the issue so tried jumpering and still no luck. Since the stat is original and so is the wire, we’re replacing both today.
    wildwest and slvrblkk like this.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    Where did you jumper it...at the stove or at the thermostat?
  7. Terry Johnson
    Terry Johnson
    Minnesota
    Stove. The two inside connections.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    Make sure one of the yellow (I believe yellow) wires didn't come off the thermostat connection block inside the stove. If that's not it, I'd re-seat the control box...make sure the stove is unplugged.
    imacman and wildwest like this.
  9. Terry Johnson
    Terry Johnson
    Minnesota
    One of the wires was undone so re-connected. Re-seated connection to controller. Still no red light.....
  10. slvrblkk
    slvrblkk
    Northampton, PA
    Remove thermostat wires and jump that thermostat terminal block.
  11. Terry Johnson
    Terry Johnson
    Minnesota
    Done and no happy.......Still no light......
  12. slvrblkk
    slvrblkk
    Northampton, PA
    Hate to say it, might be the board...I'm assuming you don't have a spare or know someone with a Contour, Santa Fe or Castile to swap boards to try?
  13. Terry Johnson
    Terry Johnson
    Minnesota
    Good assumption......we didn’t even know this style existed until we found it .
    May we confirm, is this the board? Sorry if we’re not sure:
  14. slvrblkk
    slvrblkk
    Northampton, PA
    Yes, that is the control board.
  15. slvrblkk
    slvrblkk
    Northampton, PA
    Double check the fuse by the board. I think if that were blown you wouldn't have power though.
  16. Terry Johnson
    Terry Johnson
    Minnesota
    Oh geez......any way to test it without having to spend $200?
  17. Terry Johnson
    Terry Johnson
    Minnesota
    First thing we checked-that little guy looks pretty good.
  18. slvrblkk
    slvrblkk
    Northampton, PA
    They "may" test if for you at the local Quad store. Wouldn't hurt to give them a call to check.
  19. Terry Johnson
    Terry Johnson
    Minnesota
    Now I like that idea-next......find one
  20. slvrblkk
    slvrblkk
    Northampton, PA
    I think some places have the ability to test and some not. Hopefully you can find one close.
