Put the MS 241 in some wood
Discussion in 'Chainsaws and Power Equipment' started by foragefarmer, May 25, 2014.
  1. foragefarmer
    foragefarmer
    Central, Virginia
    The 390 is 10 years old but still runs well. Thinking it is time to trade up. Run a 20" bar on the 362 and use the 440; which has been upgraded with a dual port muffler, so it isn't stock, with the 28" bar that I have for bigger wood most of the time. As it is now, I find myself not wanting to run the 390.
    And then down the road maybe sell the 440 and go to a 461. I don't really want a 660.
  2. foragefarmer
    foragefarmer
    Central, Virginia
    I think it is the same frame as the 290, so the same AV with a bigger engine. So there is more vibe than a 290.
  3. lukem
    I thought so but wasn't sure. Should be a big difference.
  4. firecracker_77
    firecracker_77
    IL
    I've run most of my saws with one bar nut missing. If I don't remember to tighten, the bar nuts on my 441 rattle loose almost every time I take it out.
    I've lost 3 bar nuts in one day before.
  5. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Congrats on the saw . Seems to be a good fit for you . Small saws rule :)
  6. Hedgerow
    Hedgerow
    SW Missouri
    Same everything as the 290 except the jug and piston...
    If you have a 390 with 170 lbs of comp, I'd not spend the coin to go with the 362...
    I'll get flamed for this, but with a simple muffler mod, the 039/390's will run very adequately... 64cc remember...
    Vibes are a bit more than the 362, but performance is close...
    I actually know a fellow in Cadillac MI, who's logging crew used primarily 039's when they came out...
    And loved them...
  7. firecracker_77
    firecracker_77
    IL
    64 cc is pretty big. The new 391 or whatever isn't cheap.
  8. MasterMech
    The 390 takes a fair bit of tweaking to get the most out of it. Post-2004 models are ridiculously choked down IMO. Same muffler as the the 290 and THAT saw loves a good muffler mod. AV is adequate for a 25 year old design but has nothing on any of the new saws. A good running 390 is going to use a fair amount of fuel compared to a modern stratocharged 2-cycle and then there is the whole m-tronic thing. :)
    Hedgerow likes this.
  9. splitoak
    splitoak
    jefferson co wv
    Yep.....first upgrade..290 to 441c:thumbs:
