My first pile
Discussion in 'The Wood Pile' started by zymguy, Aug 28, 2019.
  1. billb3
    Most want 15 amp circuits and cords, some want 20.
    Cheat on the cord gauge and the voltage drop makes heat. Heat at the plug connections and heat at the motor can shorten its life. Even old, tarnished plugs and sockets can cause heat and opens. I've had an old snowblower that wouldn't start using the most convenient outlet . I had to replace the outlet and the arc damaged plug on the extension cord. Neither were under-rated, just old.
    I have ten or twelve gauge 25 foot extension cord for mine but never tried a 14 or 16. Manual warned against it. I was putting some rather large oak rounds on it. Easy to start bending things if not careful.
    FatBoy85, Chaz, bear 1998 and 2 others like this.
  2. RGrant
    RGrant
    Connecticut
    Really remarkable job!
  3. zymguy
    zymguy
    Ely MN
    I have learned a great deal in these seven cords . I haven’t had a fire yet . I brought a v 200 home today and found out all the wood I cut 18” and longer won’t fit .
    Still happy to have the furnace, I’m thinking radial arm saw in the basement [​IMG]
    FatBoy85, Chaz, Midwinter and 5 others like this.
  4. brenndatomu
    Details man, details! :)
    FatBoy85, Chaz, Midwinter and 2 others like this.
  5. T.Jeff Veal
    That's not good.
    FatBoy85, Chaz and bear 1998 like this.
  6. brenndatomu
    Been there done that...cut 6" off every split all winter long :hair:...part of the reason I decided to go to the larger VF100...but I have ~20 cords CSS to 20-22" too...
  7. zymguy
    zymguy
    Ely MN
    Seller figures it was built early 80s . I think I’m going to bring it back to Lamppa and see how much it would cost to freshen it up , before I even take it off the trailer
  8. brenndatomu
    That's cool...be interesting to hear what they charge for such...I heard Dale say they do it from time to time.
    Is that an intake right above the loading door? Certainly different that newer models...does it have the modern computer control?
    I guess the early ones had some type of electro-mechanical controls on them (I think Daryl is still using one in his house?) (it may be updated now though...)
    FatBoy85, T.Jeff Veal, Chaz and 2 others like this.
  9. EnglishBob
    EnglishBob
    Upstate NY
    Looks like dog wood to me. Welcome to the forum.
  10. zymguy
    zymguy
    Ely MN
    Calling my first pile done. I learned a TON!!
    Burnt a little birch bark and quickly realized it was not the best use of my daylight.
    Snowing right now and 6 “ is predicted overnight. Didn’t get to clean up the yard as much as I’d have liked. My house is 71*f and my fuel oil is set at 50 f it only runs when I’m gone over 24 hours
