Stihl 026 repair
Discussion in 'Chainsaws and Power Equipment' started by Jnb, Oct 18, 2019.
  1. Jnb
    Jnb
    New Brunswick
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg I am thinking of repairing this 026 stihl, pictures of how I got it, and now cleaned up and partially torn apart. It had a muffler bolt fall out, and got caught in the exhaust port. It is going to need a muffler, sprocket cover which I hope to find used Stihl parts for them, and it will need the top end rebuilt. I cleaned up the cylinder but not shure if it will be acceptable, I sanded where the mark is just above the exhaust port and it smoothed out well but the plating is now gone where the mark is. I know there is some saw builders on here and would like to get opinions if it's ok to reuse the cylinder as it is oem, if so I would get a meteor piston and caber rings, if it is not useable I would just get a farmer tech/ Hutzl top end kit.
    Chaz, The Wood Wolverine and M2theB like this.
  2. M2theB
    M2theB
    Central Massachusetts
    I just did a top end this summer on one.
    Full meteor kit for a hundge
    I really like the saw.
    Chaz likes this.
  3. The Wood Wolverine
    I'm sure huskihl could give you some solid advice here.
    Chaz and huskihl like this.
  4. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Is that one pic of the exhaust after clean-up? Anything raised or uneven up there would be bad. You could grind away at it but you would need to know what you’re doing.
    A used OEM jug and Meteor piston would be my vote if it can’t be fixed. Missing plating above the exhaust is bad.
    Chaz and 94BULLITT like this.
  5. huskihl
    huskihl
    Hard to really tell from pics.
    First I'd file the threads off the top and side of the piston so there are no high spots. And make sure the rings slide freely in their grooves.
    Put the ring in the bore and push it up with the piston. Close your eyes and push it up over the affected exhaust area and see if you feel anything. With your eyes closed, you'll notice spots that feel "different". Then I'd put the ring right on the spot and with a flashlight look for a glint of light coming through. That should tell you if you still have a high spot.
    And then in 10 years when it finally fails I'd install a new or used OEM kit. Meteor pistons are good, but that jug will still run better than a meteor
  6. huskihl
    huskihl
    Chaz likes this.
  7. Chaz
    Chaz
    Southwestern NY
    Question..
    The cylinder & piston issues have been addressed.
    What about the connecting rod & crankshaft. I'd think those would be sketchy as well at this point.
    Issue or non-issue?
  8. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Only way to tell is close inspection of both...
    Good point, Chaz. I had a 290 in that met a sudden death. A crank lobe was cracked! First time I had seen that lol.
  9. Jnb
    Jnb
    New Brunswick
    Piston is scrap, as it has the top ring groove damaged some, the mark in the cylinder is after sanding to take the high spot out, but I will try the ring in it to be shure, the crank is still in good shape. I have a 261, 260, and 024 so this will be saw #4 and it will not get a lot of use. Where the plating is sanded off to get rid of the high spot, it extends about 1/8" above the exhaust port.
  10. JB Sawman
    JB Sawman
    pennsylvania
    Hey I would have to check to be sure in shed but I am pretty sure I have the parts you need I have 6 or 7 of those in shed for parts but shipping might be to expensive ?? let me know and I will see what I have JB
  11. Jnb
    Jnb
    New Brunswick
    Yes let me know Jb Sawman, if shipping isn't to bad I would like to try to keep everything oem, I can send you a message with shipping address if you want.
    GrJfer and The Wood Wolverine like this.
