Military cargo trailer with pintle hook
Discussion in 'The Wood Pile' started by Yawner, Oct 7, 2019.
  1. Yawner
    Yawner
    Louisiana
    I came across a military cargo trailer painted camo. It has steel (vertical) and wooden (horizontal) frames on both sides, no frames front or back, they're open. Up top, has steel arches that I guess can be moved toward the rear to form a structure such that a canvas fabric goes on it. It looks similar to the one in the attached pic. It looks brand new, maybe it's just reconditioned, I haven't seen it in person yet. Has brakes (I don't have truck brakes), spare tire, pintle hitch, tailgate, new tires, lights, has Rhino-lined bed and he thinks it's 6'x10'. It's 3 ft off ground. I wonder why they are so high? I guess traversing rivers and such? He's asking $800. Wonder what it's worth?
    I would buy this to haul firewood and also to occasionally haul a 4-wheeler and if it will fit, a John Deere Gator. Hmmm... unsure how you'd strap down either of those. No tie downs in bed that I can see. I would think this trailer would be super heavy duty but it has a pintle hitch. Never had a trailer with one, wondering if it would be sloppy hook-up and be loud and aggravating? I also am concerned it's so high off ground, wondering if that will make it pull weird, or if it will be impractical to load/unload. But, that's the height of my pickup truck tailgate.
    I don't have a pintle hitch for my truck, so, I would have to buy one, that's a negative. I hope it has a jackstand, if not, would have to buy that, too.
    Tow vehicle would be a 1/2 ton Nissan Titan.
    Lastly, the guy says he has no title. I saw one on Ebay for $1,800 and it said "government title." So, I wonder how I would get a license plate for it.
    Any comments on this type trailer, value, features, etc. appreciated. TIA!
  2. T.Jeff Veal
    Should be fine. Pintle hitch makes a little noise, but easy to hook up. Just buy hook to go on your truck. Our pastor just bought 2 of them. Good ground clearance. $900 not to bad.
  3. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Looks like a winner to me. All I’ve been told is wheels and tires Aren’t anything normal so that can be a pain sown the road. Otherwise, built to last and many of them can dump.
  4. Yawner
    Yawner
    Louisiana
    FWIW, this trailer was a no go, it's just way too tall. And heavy. The guy is a mechanic and had it hooked up to a 4wd bigass military truck that used to be 6wd, he completely refurbished it, looks brand new. He's quite the mechanic. He said you'd need probably a military truck to pull it. I don't know why he didn't share that wisdom prior to me driving 50 miles to see it!
    Now, if I had a 3/4 truck that was jacked up way off the ground, it might work. The bed floor is about same height as a standard pickup truck bed. Very nice trailer though, heavy duty. It would be nice to find something like that a regular truck could pull.
  5. bogydave
    IMO, For me, the bed is too high.
    Lifting too high to load.
    My ole back cries enough.
    Looks heavy duty though.
  6. billb3
    T.Jeff Veal and Woodsnwoods like this.
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have two of these, both without the racks. They are high off the ground, but tow very well and smooth. I paid maybe 800 per trailer directly from the army. I have used them on road, but I use these now 100% offraod behind my tractor.
    T.Jeff Veal and Backwoods Savage like this.
  8. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
  9. JotulYokel
    JotulYokel
    Missouri
    "No Title" could be a problem, or not, depending on where you live.
  10. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    You can buy a 12V conversion kit for these, or simply buy the $20 walmart add ons. In NY, you can register these as homemade, requiring a NYSDOT inspection prior to approval. It is not hard. I will say the biggest challenge I have is they do not dump, which is why I bought the large dump trailer.
