Stihl 044 air leak?
Discussion in 'Chainsaws and Power Equipment' started by Andimus Prime, Sep 24, 2019.
  1. Andimus Prime
    Andimus Prime
    NW NC
    I picked up all my parts the other day. Am I really to pick up a case splitter and flywheel puller?
    M2theB, Chaz, Nixon and 2 others like this.
  2. bigfrank
    bigfrank
    NorCal
    He knows what he's talking about.
    M2theB and Chaz like this.
  3. Andimus Prime
    Andimus Prime
    NW NC
    I thought so too. How bout these? Are there any forum sponsors selling them?
    Chaz likes this.
  4. dall
    dall
    West Virginia
    there are some pullers that have 2 different sizes and you will need the second size if you do 066
  5. dall
    dall
    West Virginia
  6. Andimus Prime
    Andimus Prime
    NW NC
    No plans on going that big yet, but maybe someday! :yes:
  7. dall
    dall
    West Virginia
    lol they are not that much bigger
  8. Jnb
    Jnb
    New Brunswick
    You shouldn't need a flywheel puller, just take the flywheel nut off and a tap or 2 with a good centre punch and hammer and it should pop off. Look it up on utube, there should be some videos showing that.
    M2theB and brenndatomu like this.
  9. Andimus Prime
    Andimus Prime
    NW NC
    20 cc is a pretty big jump for me. I haven’t had a chance to put this saw in wood yet, looking forward to it though.
    brenndatomu likes this.
  10. Andimus Prime
    Andimus Prime
    NW NC
    I’ll give it a shot!
  11. brenndatomu
    Sounds good...but never works for me...
    M2theB, cnice_37 and Andimus Prime like this.
  12. cnice_37
    cnice_37
    I welded 2 nuts on a bolt for the "puller". Just thread to bottom of bolt (one nut is flush with bolt bottom, the other gets welded to that but and sits proud of the bolt) and hold by flywheel and one good whack sets her free.
    M2theB, Andimus Prime and brenndatomu like this.
  13. bigfrank
    bigfrank
    NorCal
    I a!ways take the nut off, then put it back on 3 or so threads and tap the nut with the hammer. Comes right off.
    brenndatomu and M2theB like this.
  14. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    That method works fine for some saws. My experience is that the larger saws and Stihls with poly flywheels can be stubborn. The pullers work great with limited stress on the crankshaft and fw.
    Hammer and punch- great for 250, 290, 361, etc. Tough for older 1122s and poly fws 1128s.
    dall and brenndatomu like this.
  15. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    That case splitter should be good for you. I have the oem Husky version and have split dozens of saws over the years with it (Stihl, Husky, Dolmars).
  16. Andimus Prime
    Andimus Prime
    NW NC
    So almost 4 months later... I’ve got the jug off, still haven’t ordered a flywheel puller or case splitter though. I may order that this weekend. I’m thinking this piston and cylinder looks ok though!
    3CAFCB36-C561-4836-8FD3-05B25C6EC4AE.jpeg D053CD7B-DB18-42A0-915C-66A9FA7B40DF.jpeg 4F80D690-613B-40A0-ABD7-36696E3DB240.jpeg
    M2theB likes this.
  17. dall
    dall
    West Virginia
    looks like bar oil or very rich condition
    which saved the piston and cylinder
    i have seen the case gasket go bad and let bar oil get sucked through from the oil tank but you will be changing it out as well
  18. Andimus Prime
    Andimus Prime
    NW NC
    I think I had it pretty rich trying to straighten the idle up. The film of oil on the bottom of the piston felt thinner than bar oil to me.
    M2theB and dall like this.
  19. dall
    dall
    West Virginia
    hard to tell unless you can have it in hand
    Andimus Prime likes this.
  20. Andimus Prime
    Andimus Prime
    NW NC
    I didn’t notice it when I pulled the cylinder but I don’t think there was a gasket between it and the case.
    M2theB likes this.
