Saw shutting off
Discussion in 'Chainsaws and Power Equipment' started by Woodwhore, Oct 1, 2019.
  1. Woodwhore
    Woodwhore
    Mason NH
    hey friends 576xp Husky- wouldn’t start back up, i took the cover off and it started rt up but as i was putting the cover back on while running it would shut down. I know i hit the compression button a couple times and that shut it down. It still shut off even when i realized that and would be careful not to hit it. I moved the spark plug wire around and that seemed to work. Theres no melted exposed wire either. I did get a shock one time when touching something but that only happened once. Any thoughts?????
  2. M2theB
    M2theB
    Central Massachusetts
    Ground/kill connection loose or off its post at the choke/kill switch
    Could check it under the flywheel cover too
    tamarack, Chaz, Ronaldo and 2 others like this.
  3. Farmchuck
    Farmchuck
    Nepa
    U just need to trade that puppy in on a 572xp is all. You can’t be expected to be productive with substandard equipment:)
    Just kidding, I really don’t know what could be causing that sir. Unless you have a bare spot in the plug Eire that is grounding it out on something it’s coming in contact with when you put the cover on.
    M2theB, Chaz, Woodwhore and 2 others like this.
  4. Farmchuck
    Farmchuck
    Nepa
    Plug wire
    tamarack, M2theB, Chaz and 3 others like this.
  5. Woodwhore
    Woodwhore
    Mason NH
    Is there a big difference between those two saws??
    M2theB, Chaz and Farmchuck like this.
  6. clemsonfor
    Tape up or replace all damaged wires. If the plug wire is bare or not insulated it is arching to ground before it can fire the plug. This could be your issue. That needs to be fixed first.
    Sent from my moto g(7) using Tapatalk
    M2theB, Chaz and Woodwhore like this.
  7. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Send it to me and I’ll run it for a couple years and let you know what I found :whistle:
  8. Sandhillbilly
    Sandhillbilly
    Or do like Farmchuck suggested and trade it off, just be sure to let me know where you traded it in
  9. Woodwhore
    Woodwhore
    Mason NH
    is it worth having someone do like a tune up on it. I clean it out and keep it as nice as i can, change out plug and filter but I also dont have the money really for that.
    M2theB and Chaz like this.
  10. Farmchuck
    Farmchuck
    Nepa
    572 is the latest 70cc saw Husqvarna cane out with & it’s been drawing a lot of positive feedback from the professionals from what I’ve been reading.
  11. Woodwhore
    Woodwhore
    Mason NH
    Iv had my 455 rancher for many years, iv been using the 576 cus the oiler is clogged on the 455. I absolutely love that saw and its cut alot of wood. 576 is just so heavy for what im doing but its nice to play with and also have for the occasional large tree. Rt now its got a 20” bar and its a beast but when i buy a new saw i would want another lighter cordwood saw. Thats why i love that little echo you see in my pics, its so light and it really surprises me.
    M2theB, The Wood Wolverine and Chaz like this.
  12. Chaz
    Chaz
    Southwestern NY
    This seems a likely culprit, especially considering you got a jolt.
