Shoulder season around the corner...
Discussion in 'The Pellet Bag' started by Tullytown, Sep 27, 2019.
  1. Tullytown
    Tullytown
    North of Phila Eagles.
    Usually starts around mid October or so here in the mid-Atlantic.. nitetime temps start to drop...
    in the shoulder season, my glass get's dirty quicker from the on/off cycle thruout the day with a bit more ash.
    cheap pellets or top of the line softwoods, same deal..[although the cheaper pellets do make a mound of ash]...
    so, i just burn the same softwoods from fall to spring. makes no difference for me to have a shoulder pellet.
    when my stove starts to run 24/7, then the difference is very noticeable.
    less ash/cleaner glass..:salute:
  2. MikeInMa
    It's here now. Having morning fires to chase off the chill.
  3. jtakeman
    Hopefully hold off until 10/01
    2/3 of the supply is kitty-d! :D
  4. bogieb
    Put the 3rd bag of pellets into the P43 the other day (MWPs). We have had a see-saw of temps - sometimes low 40's at night, sometimes in the mid 60's. Started the stove up on 9/7 - two days earlier than last year, but I've used less (at this point last year I was at 4-5 bags).
    I don't tend to have separate types of pellets for different times of year unless I can find a good deal on Vermonts or some other great brand at a low price on CL. Those I will hang onto until mid Jan. to mid Feb.
  5. Rich250
    Rich250
    Berks County PA.
    Of all the different pellets I have tried ( which is all pretty much chit around here ) I can't notice enough of a difference to even worry about shoulder pellets, so my approach is buy what is cheapest and close to pick up, when the glass gets dirty I clean it, when the burn pot develops a speed bump I scrape it, and when the stove needs a complete cleaning I clean it.
  6. Lousyweather
    Lousyweather
    Words to live by!
  7. Rich250
    Rich250
    Berks County PA.
    :thumbs:
  8. unbidden
    unbidden
    RI
    'Shoulder season'
    I lug my pellet bags into the house over my SHOULDER no matter what month it is :yes:
  9. Tullytown
    Tullytown
    Although nothing to do with the post, forgot to mention that after five years of burning, I finally realized that stove temp keeps us the warmest throughout the year. Kind of stayed away from it because I always read that you burn more pellets in stove temp mode at least for a Harman. Was trying to do the impossible which was stay toasty warm and save pellets at the same time. Last year I was able to drop my feed rate from four down to three so really only used about 10 bags more than I did the previous years. But during shoulder season can't run on stove mode as it gets just too damm hot in the house and I do not want to lower the feed rate any more than three so I live with the on-off routine till it gets steady cold. By the way was this website down for five or six days as I could not get on or was it me?
  10. Luneyburg
    Luneyburg
    Hills of Central Mass
    Yessir same here just 20 miles north of ya Mike, we bit chilly in the morning .
  11. subsailor
    subsailor
    Winthrop, Maine
    Room temp mode fall and spring, stove temp once the stove runs steady.
  12. will711
    will711
    Pocono Mts.
    Well said Rich , that's what I do and it works Well :cheers::cheers:
  13. Rich250
    Rich250
    Berks County PA.
  14. Pete Zahria
    Pete Zahria
    New Hampster
    Me either......
    :yes:
    Dan
  15. Russell
    Russell
    South Coast , Massachusetts
    I've been burning for about a month now early morning for either a slight chill or to keep the inside of the stove dry . Just adjusted thermostat to 73 with a swing setting of 2.25 degrees . Classic Bay 1200 in the basement. . Using Stove Chow at the moment until I start loading up on Vermont's . When stove is running 24/7 I'll move up to 74 and use the medium setting and that should do it.
    slvrblkk, Rich250, Dpopps and 5 others like this.
  16. will711
    will711
    Pocono Mts.
    Russell I'm gonna be using a lot of that this season as 6 ton of Chow is scheduled for delivery tomorrow :thumbs::cheers::cheers::cheers:
    eatonpcat, slvrblkk, Russell and 5 others like this.
  17. Russell
    Russell
    From HD I figure ?
  18. will711
    will711
    Pocono Mts.
    Yup
    slvrblkk, ttdberg, Russell and 2 others like this.
  19. Tullytown
    Tullytown
    259 a ton at Home Depot. Same as last few years.
    slvrblkk, bogieb and Russell like this.
  20. bogieb
    Yesterday the HD 30 miles from me had a sign up that said 6+ tons at 219/ton. Course I'm sure that doesn't include delivery. I think smaller tonnage was at 249/ton, but I could be mis-remembering on that - maybe it was 259.
    Russell, slvrblkk and ttdberg like this.
