Trailer build project
Discussion in 'Hobbies and Interests' started by Need2Saw, Sep 24, 2019.
  1. Need2Saw
    Need2Saw
    Central Michigan
    I decided I needed a trailer to haul multiple sxs units (Polaris rangers). I found that most trailer with enough length were way over built for the payload that would be on it, so I decided to build my own.
    This started off as a 29” travel trailer. I bought it already torn down to the frame and axles.
    I added crossmembers and side rails to strengthen it. Finished Deck length is 24’9” and deck width is 70”.
  2. Need2Saw
    Need2Saw
    Central Michigan
    I added fenders, installed new brakes on both axles, new bearings and seals. Primed and painted.
    Boogeyman, Chvymn99, huskihl and 7 others like this.
  3. Need2Saw
    Need2Saw
    Central Michigan
    I added lights, wiring and decking. The decking I predrilled through the boards and into the cross members, then used self tapping trailer flooring screws. I coated the decking with Thompson’s water seal
    Boogeyman, Thor, Chvymn99 and 7 others like this.
  4. Need2Saw
    Need2Saw
    Central Michigan
    I added new tires/wheels and weighed it. Finished weight was 2168lbs. The axles are rated at 3500lb each. That allows me to comfortably haul 2 units. It a solid trailer and it pulls great, I’m happy with the way it turned out.
    Last thing to do was put it to use.
    Boogeyman, Thor, Chvymn99 and 9 others like this.
  5. dall
    dall
    West Virginia
    was you at kevins gtg ?
  6. Need2Saw
    Need2Saw
    Central Michigan
    Yes, I was there most of the day Saturday.
  7. dall
    dall
    West Virginia
    i remember someone saying the name but cant remember your name lol
  8. dall
    dall
    West Virginia
    foster ?
  9. Need2Saw
    Need2Saw
    Central Michigan
    Nathan, I had a good time up there. I think I tried out a couple of your saws, I’m not a Stihl man but I did like that 462.
  10. dall
    dall
    West Virginia
    pretty cool build
    what does a sxs weigh 1000 to 1200 pounds ?
  11. Need2Saw
    Need2Saw
    Central Michigan
    Mine is a ranger 1000 with a few accessories and it weighs just under 1800 on the farm scales.
  12. dall
    dall
    West Virginia
    didnt think they was that much
    and a double axle trailer does pull better
  13. brenndatomu
  14. brenndatomu
    Yeah, they hurt a lot laying on your leg...:hair: :faint: :doh:
    Thor, Chvymn99, eatonpcat and 3 others like this.
  15. dall
    dall
    West Virginia
    never owned one but did have a 300ex on me years ago and at 400 pounds it was heavy enough
  16. brenndatomu
    Flipping a sport quad on you is not good...the big Vtwin 4x4's are worse...but the SxS machines are in a league of their own! Free advice...wear your seatbelt!
  17. T.Jeff Veal
    Nice work on that trailer build. Looks great
  18. Warner
    Nice work. Did the Thompson’s make the deck slippery?
  19. eatonpcat
    PU$$......!:p:rofl: :lol:
    Thor, Chvymn99 and T.Jeff Veal like this.
  20. eatonpcat
    Good question.
    Great reuse of an old travel trailer, that thing looks sweet!! About how much do you have into it??
