Husqvarna 372xpw scatter
Discussion in 'Chainsaws and Power Equipment' started by bigfrank, Sep 22, 2019.
  1. bigfrank
    bigfrank
    NorCal
    Was running my 372 the other day and it quit running. Just got a chance to pull it down and this is what I found. Still not 100 percent sure what caused it, but it looks like a ring broke and somehow some pieces got into the combustion chamber and hammered it. Looks like the beast will have a fresh top end...
    MFMc., eatonpcat, TurboDiesel and 9 others like this.
  2. papadave
    That'll buff right out. :yes::picard:
    Ouch.
  3. MikeInMa
    Ugh can't like that.
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  5. M2theB
    M2theB
    Central Massachusetts
    Interesting, both ends of the lower ring are gone.
  6. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    IT’S A CONSPIRACY MAAAAAANNNNNNNNNNN.
  7. The Wood Wolverine
  8. Stephiedoll
    Stephiedoll
    Omaha, NE.
  9. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Watch for metal bits in the case. I’d consider splitting that one unless you’re confident you got all the pieces.
    Also wiggle that crank and check for play.
    M2theB, bigfrank and huskihl like this.
  10. bigfrank
    bigfrank
    NorCal
    Thanks. Did the k the crank and I thi k it looks okay. Flushed out the crs k case and it looks clean. Rely Ed the crank bearing, and will probably try and get it back together tomorrow.
    M2theB and eatonpcat like this.
