Husqvarna 365 issue.
Discussion in 'Chainsaws and Power Equipment' started by BToebben, Sep 20, 2019.
  1. BToebben
    BToebben
    Missouri
    I have a 365 that cuts crooked. I have replaced the bar with a new one and put on new chains. Does anyone have other suggestions as what it could possibly be. Thanks for any help
  2. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Are you using the dogs to pry thru the cut? I’ve struggled with that at times, and think with single dogs, it’s best to let the chain pull the saw thru and not the dogs. Ymmv
  3. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    May sound dumb but make sure the chain gage matches the bar.
  4. BToebben
    BToebben
    Missouri
    Thanks for the replies. I’m going to recheck the chain, knowing me I probably got the wrong size. I do have a double dogs on it the outside one I got for it when the saw was given to me. My brother found it in a dumpster. Thanks again guys.
  5. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Wish I could find a 365 in a dumpster. Or pretty much any saw other than an old small p.0.s. Homelite
  6. The Wood Wolverine
    Hmmm, new bar, new chain. Are the dogs square to the bar(or are they equal lengths)?
  7. jo191145
    Besides all the other good suggestions placement of your left hand may make a difference. Solved the problem on my 372
  8. BToebben
    BToebben
    Missouri
    He works for the local electric power company and was in the St.Charles area. He had to throw some stuff away and there it was. I put about 150 in into it. Runs great. By the way do you have retriever?
  9. Sandhillbilly
    Sandhillbilly
    A retriever?? No. I do have a beagle though.
  10. Andyshine77
    Andyshine77
    Cincinnati, OH
    Check the rim sprocket as well, could be causing premature where to the chains drive links. If you have to force the saw through the cut the chain is dull.
    M2theB, Brandon Scott and TurboDiesel like this.
