Husky 460 parts question
Discussion in 'Chainsaws and Power Equipment' started by CNE deer, Sep 19, 2019.
  1. CNE deer
    CNE deer
    ohio
    Have a husqvarna 460 the chain popped off yesterday, no biggie so trying to reassemble the adjuster wont move , can I just buy that adjuster or do I have to buy the cover. Thanks in advance. Jim
    T.Jeff Veal and M2theB like this.
  2. Fifelaker
    Fifelaker
    Fife Lake Mi.
    There are a few variations of that saw and I don't know if they are all the same or not PartsTree has the IPL's online and it looks like you can buy the parts separate.
  3. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I’ve had good luck with HLsupply don’t know if they have anything for a 460. They don’t have a handlebar for my 345 though.
    T.Jeff Veal, clemsonfor and M2theB like this.
  4. CNE deer
    CNE deer
    ohio
    Thanks guys
    T.Jeff Veal and clemsonfor like this.
  5. CNE deer
    CNE deer
    ohio
    Might need some additional help , purchased the gear drive parts, the bar wont adjust and the new gear seems to bind up , anything I should look for, is the cover bad ??
  6. dougand3
    dougand3
    North Alabama
    See if you have all the parts.
    T.Jeff Veal likes this.
  7. M2theB
    M2theB
    Central Massachusetts
    Confirm you’ve got the pitch matched correctly, sprocket to bar.
    .325 or 3/8 likely
    T.Jeff Veal, clemsonfor and CNE deer like this.
  8. clemsonfor
    The adjuster is basically a specialty but that rides along a threaded rod. It's brilliant and simple at the same time.
    You are loosening the bar nuts right? My neighbor couldn't tighten his chain and busted an adjuster. Bought a replacement and still couldn't get the chain tight?? I went over tightened the chain up and he said how did you do that? I said I just tightened it?? What do you mean? How do you do it? And I then said you are loosening the bar nuts right...he said no!! I said no wonder it won't tighten up!
    I really don't think your doing that since you actually have cut firewood for years though.
    T.Jeff Veal and dougand3 like this.
  9. CNE deer
    CNE deer
    ohio
    I got it ! Got the bar on and was able to get the chain adjusted:thumbs::thumbs: Still baffles me how a adjuster binds up
  10. dougand3
    dougand3
    North Alabama
    Like Clemsonfor said....I bet your bar nuts weren't loose enough. Maybe this clutch cover is shaped to stay tighter with slightly loose nuts. Give them 1.5-2.0 CCW turns before adjusting.
    M2theB, T.Jeff Veal and CNE deer like this.
  11. CNE deer
    CNE deer
    ohio
    Took the cover off and the adjuster wouldn't turn at all:mad:
  12. clemsonfor
    Is the cover bent or warped? It's plastic right.
    Is there trash like sawdust in the track?
    Sent from my moto g(7) using Tapatalk
  13. dougand3
    dougand3
    North Alabama
    Gotta be the 2 gears to turn slot 90*. See what's binding.
    Another option: Drill hole in front, Get bolt that fits pin nut (I'd guess M5) and screw from the front. 99% of saws do it that way. I guess Husky had to act like Stihl and over-engineer something.
    clemsonfor likes this.
