19x13 and ~ 7 foot ceiling plan needed
Discussion in 'The Wood Pile' started by zymguy, Aug 28, 2019.
  1. zymguy
    zymguy
    Ely MN
    I believe it’ll hold about 13 cords .
    I bought 7 cords that I need to cut and split , they will not likely be very useful this season . I don’t know how much but I’ll buy dried cut and split if I can find it and I’ll be able to harvest some dry standing.
    I’d like to buy more ( wet ) [​IMG][​IMG]again early spring 2020 to continue to get ahead .
    1400 ft house , decent insulation in northern mn add on stove in the basement will just fit a 21” .
    How should I stack this woodshed ?
    bear 1998, T.Jeff Veal, Chaz and 12 others like this.
  2. DaveGunter
    DaveGunter
    Stack it full:D
    Seriously though, that's a nice looking shed open sides will help the drying a lot. I wouldn't plan on using any of that wood this year. Stacking the split wood outside of the shed in long single rows for a year and then move it to the shed will help it dry faster. As for this year, can you source some kiln dried wood?
    bear 1998, Chaz, Lone_Gun and 3 others like this.
  3. Backwoods Savage
    Primer on Woodburning by Backwoods Savage
    Nice woodshed! If the wood has not had good drying time, be sure to split it smaller and don't try to stack it really tight as that will hinder the drying. Stack it a bit loose even though this means you won't be able to stack it as high. Good luck.
  4. FatBoy85
    FatBoy85
    Washington State
    Hopefully you can find some already “dry enough” wood and then work on your future stuff in the meantime. Looks like one heck of a shed. Some of these great hoarders here have something just as great so if you find that thread that shows wood stores, there are some just have a bin for every year and their respective kindling bay as well. If you needed an idea for organizing, this would be a thread to read.
    I might enlist an admin Eric VW, if he knows this well. I’m a forgetful one at titles, you know about that thread that probably went about 20-30 pages of Woodsheds?
  5. MikeInMa
    Depending on how accessible that shed it, you could store pallets of compressed wood logs there, and use those this year for heat
  6. zymguy
    zymguy
    Ely MN
    Pallets of compressed wood logs ??
    There is also a fuel oil furnace, I’ve never heard of compressed log but it may not be cheaper than fuel oils because I’d have to ship it
  7. Eric VW
    Moderator....:salute:
    Y’all can peruse these results from a perfunctory search-:yes:k
    Search Results for Query: Wood shed | Firewood Hoarders Club
    bear 1998, Chaz, imwiley1 and 4 others like this.
  8. MikeInMa
    Like these -
    RedStone Wood Fuel, Pack of 6, ECOBRICK at Tractor Supply Co.
  9. Canadian border VT
    zymguy not now but in the future, you might want to run an efficiency test on the furnace. When I bought my home I had a TARM multi-fuel furnace. The challenge was it didn't use any fuel efficiently.
  10. zymguy
    zymguy
    Ely MN
    It’s a first generation kuuma. I don’t know anything, but I’ve been led to believe it is worth using
  11. Canadian border VT
    Kuuma have a great reputation:yes:
  12. FatBoy85
    FatBoy85
    Washington State
  13. FatBoy85
    FatBoy85
    Washington State
    As long as they stay dry..if they don’t it’s like looking at a woodworkers bench, sawdust pile.
  14. zymguy
    zymguy
    Ely MN
    I’m sure that there is more math to it than simply BTU per pound or more relevant BTU per fog skin. But a pound of #2 has 16,000 BTU and cost close to $0.75( I’m assuming 7# /gallon @ 5$ )
    Ecobrick look to be very approximately a buck a pound at 8000 btu .
  15. Paul bunion
    Paul bunion
    Best answer!
  16. In the Pines
    In the Pines
    7.38 pounds a gallon for #2.
    amateur cutter likes this.
  17. zymguy
    zymguy
    Ely MN
    New development, demands planning . Wasps , or maybe hornets ? They’re somewhat in my house .
    I don’t have a normal sort of basement windows. The stairs you’d take from inside are more like a ladder . Fortunately there’s a walk out door-ish opening on the gable end . Hasn’t been opened in years , a very effective crude ugly cobbled r19 Fiberglas hang job insulation covers the door on the inside . I banged on the inside slide lock and lifted the insulation, never upset or was aware of a wasps . When I went to the outside, I was informed my agenda was in conflict with these striped insects. [​IMG][​IMG]
  18. zymguy
    zymguy
    Ely MN
    Should I put pallets or anything else down in the woodshed?
  19. zymguy
    zymguy
    Ely MN
    [​IMG][​IMG]
    When I first noticed this I thought I’d just replace the sheet of roofing. Now I’m looking and Rita gonna be a pain !
