Zerk fitting recommendations
Discussion in 'The DIY Room' started by rusty ranger 44, Jan 13, 2021.
  1. rusty ranger 44
    rusty ranger 44
    south central Pa
    I am looking for info as to how to install zerk fittings in my wheelbarrow wheel for better lubrication. These wheels are for airless tires and do not bolt together. the problem is the center hub does not extend past the outer hub.
    Screwloose likes this.
  2. TurboDiesel
    Picture might help. Cant get in the drill the center?
    Pull the axle shaft out, pump grease into hub, push shaft back in. A wheel barrel cant use much grease
    Slocum, Screwloose, huskihl and 2 others like this.
  3. rusty ranger 44
    rusty ranger 44
    south central Pa
    Thanks I ll give that a try
    Slocum and Screwloose like this.
