Where would I buy a MC meter, and how much is reasonable
Discussion in 'The Wood Pile' started by riks, Mar 4, 2015.
  1. riks
    riks
    Conneautville, PA
    I live in an area where we have big box stores, Lowes, Home Depot, plus many smaller hardware stores. Instead of guessing, it would be nice get a better idea, of which methods work best for drying times. Thanks
    HDRock, Chvymn99, bearverine and 2 others like this.
  2. wildwest
    Wyoming high plains
    Seems like a lot of members here have a yellow one ~$20 from HD or Lowes and it does the job for them.
    Chvymn99 and Shawn Curry like this.
  3. HDRock
    Chvymn99, Horkn and wildwest like this.
  4. KaptJaq
    KaptJaq
    Long Island, NY
  5. MightyWhitey
    MightyWhitey
    According to Backwoods Savage, the best moisture meter is the "3 years ahead" on CSSed firewood!! No guess work then.
  6. yooperdave
    Menards has 'em for about $14.
    Horkn, HDRock and wildwest like this.
  7. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I haven't said this in a long time: "The best device for determining the moisture content of split firewood is a multi-year calendar." That being said, Lowe's has a General Tool meter for $20 or so and it does just fine. I strongly recommend you go on the 3 year plan if you have the space. It's the only way to fly....er... burn!
    NH_Wood, Chvymn99, papadave and 2 others like this.
  8. Paul bunion
    Paul bunion
    If you want to track drying progress while you experiment with your stacks I would suggest you use a scale. If you stack up similar splits in different conditions and you can easily compare methods by looking at their weight. One of the shortfalls to a moisture meter is that it requires you to destroy your test specimens to measure the insides. That makes it kind of difficult to take repeated measurements as you try and figure out what works and what doesn't and why. A moisture meter is also only accurate on wood up to about the mid thirties. If your wood is green you'll be unable to measure your starting points for a large number of species. Get some slow going oak and you might be waiting a while before you even get anything meaningful.
  9. Woodrat1276
    Woodrat1276
    Ky
    All the guys I know who burn or sell wood don't have a moisture meter myself included. They however burn green and sell green so one isn't really needed in their case because they don't care I however refuse to burn green wood I've tossed the idea around a little on buying one but have not.
    I really don't think one is neccesary unless you buy your wood and the seller is stating it is seasoned. Get on a two year or more plan.
    NH_Wood and wildwest like this.
  10. riks
    riks
    Conneautville, PA
    Hey, thanks everybody for your feedback. I do realize that a 3 year plan is the surest way, and as I found out the drier the wood the less wood I burn.
    NH_Wood, wildwest, HDRock and 2 others like this.
  11. Chvymn99
    Spoken like an experienced burner...:yes:... Welcome to FHC!
    wildwest likes this.
  12. oldspark
    oldspark
    NW Iowa
    Nothing wrong with the MM's, just a handy tool to make a quick check, I am over 3 years ahead but I still use mine once in while.
    The cheap Harbor Freight one has been good for me.
    NH_Wood, wildwest and HDRock like this.
  13. HDRock
    I think a moisture meter is necessary.
    The question was, where to buy a moisture meter ?
  14. oldspark
    oldspark
    NW Iowa
    Some seem to have a problem with comprehension .
    Guy wants to buy a MM so help him out or shut your pie hole!:D
  15. prell 73
    prell 73
    ia
    Home Depot is were I got mine 20$
  16. bushpilot
    bushpilot
    Eastern Washington
    eBay, forgot the price, but less than $20.
  17. ErikR
    ErikR
    Deep in the woods near Cable, WI
    I use the cheap one from Harbor Freight. To save a few bucks when it needs batteries, I buy A544 camera batteries and peel the tin off the outside. Inside are the 4 LR44 button cell batteries needed for the moisture meter.
  18. HDRock
    Thanks , Good to know , the batteries are the only thing I don't like about that one , it's in need of bats right now
  19. oldspark
    oldspark
    NW Iowa
    Found some cheap batteries on ebay for my harbor freight MM and I take them out when not using it, they last much longer.
    HDRock likes this.
