what to use for the floor of the pizza oven
Discussion in 'The Smokehouse' started by Hog_Hunter_57, Jun 5, 2015.
  1. Hog_Hunter_57
    Hog_Hunter_57
    Mt.Pleasant TX
    What are you guys using for the floor on your wood fired pizza oven?
    Eric VW and wildwest like this.
  2. Scotty Overkill
    Firebrick done in a herringbone pattern would probably be ideal, maybe ask fishingpol or ironpony for some input. I'm planning on building one later this summer as well....
    axeman, WoodovenAT, papadave and 2 others like this.
  3. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Yah, red firebrick over mason sand. Never a problem with grit on the bottom of pizza or calzones. Very durable so far.
    Watcha up to?:popcorn:
  4. ironpony
    ironpony
    Mid Ohio
    medium density refractory, cast in mold.
  5. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Ironpony,
    Excuse my ignorance, did you cast that in place or did you purchase it already cast?
    Do you have a link?
    One of my guys that used to work with me wants to go in with me to build a pizza oven on a trailer so that we can each use it and take it to parties to use at other peoples houses. Andrew has photos of ones he has seen. They look pretty cool.
    But, we are thinking a foam insulated bottom with a cast in place refractory would be the ticket.
    Eric VW likes this.
  6. Eric VW
    ironpony- I too am a little ignorant on this "medium density" castable... Do you mean like "Mizzou?" which is a dense castable, or did you get a bucket of ready mix, something like "Rutland?"
  7. WoodovenAT
    WoodovenAT
    New Jersey
    Hey , I set my tan 4 1/2" on edge directly on 2" of ceramic fiber board insulation. I sat the insulation on aluminum u channel with some stainless steel perforated metal , just so the heat had a harder time migrating into the slab. I built my oven to hold heat for a long time though, I highly recommend you insulate under the firebricks
    Minnesota Marty and Eric VW like this.
  8. WoodovenAT
    WoodovenAT
    New Jersey
    https://instagram.com/p/mvPetAjDb3/
    I'm not sure the link will work, but you could see this mockup that I did, it doesn't show the ceramic fiber board, but the u channel is there.. The board was placed between the two.
  9. Eric VW
    Ah ha! the "AT" doesn't stand for Appalachian Trail, does it WoodovenAT? :whistle: :rofl: :lol:
    WoodovenAT likes this.
  10. ironpony
    ironpony
    Mid Ohio
    It is cast in place over light density insulating refractory. there are some pics on here somewhere, I am not that computer savy. medium density as in X lbs per cubic foot. I worked with a local furnace suppliers engineer and he specd everything for me.
    on a trailer I would go with cast there is a lot less joints to come apart. my oven is 6 pieces total. the dome is 4 pie shape pieces and a center plug, then the base. I will post some pics here.
    basically I built a plaster mold, cast the dome in 5 pieces. then the base was cast in place and the dome set on top.
  11. Eric VW
    Sounds like you put some serious effort towards your project, ironpony.
    What's your wood of choice for firing yours?
  12. ironpony
    ironpony
    Mid Ohio
  13. ironpony
    ironpony
    Mid Ohio
    whatever burns........
    eatonpcat and Eric VW like this.
  14. ironpony
    ironpony
    Mid Ohio
    the purpose of the round plug is so the points do not crack off from expansion and contraction
    eatonpcat, campinspecter and Eric VW like this.
  15. Eric VW
    Wow! Thats incredible, ironpony!
    Last Fall, I bought some Tough Shot 2600 for use in my potential Rocket stove... didn't realize it was for gunning- called the warehouse and the rep said there was a guy in Floyd who used the same thing for Pizza Oven floors... Any thoughts? I ended up figuring out a way to ram it into my mold, and pound the air pockets out... I'll try to find some pics....
  16. Eric VW
    Ok, just thought maybe you had a wood of choice....
  17. ironpony
    ironpony
    Mid Ohio
    not really, I used what the 30 year furnace engineer specd, did not do a lot of extra research. got lucky as it is a small family company and they were willing to work with me and sell me the small quantity I needed.
    Eric VW likes this.
  18. Eric VW
    Would be nice to see a set of vid clips on the firing, raking/pushing of coals, and the placement of food to be cooked, and of course, the end results!!! :drool:
    Anyone?
  19. ironpony
    ironpony
    Mid Ohio
    this is with the light weight in place
  20. ironpony
    ironpony
    Mid Ohio
    first pizza a couple years ago
    basod, axeman, eatonpcat and 2 others like this.
