Weed Wacker Problems........
Discussion in 'Chainsaws and Power Equipment' started by MightyWhitey, Aug 10, 2017.
  1. MightyWhitey
    MightyWhitey
    Starts like normal..........runs normal until warmed up. Then bogs out and/or dies when throttle is applied. I can feather the throttle to get the her to run well..........but then when a load is placed on engine, she bogs out and dies.
    New plug, cleaned air filter.
    PoulanPro PPB100
  2. Mag Craft
    Mag Craft
    South East Wyoming
    The carburetor probably needs to have a kit installed. The diaphragms are probably stiff and need replaced. You can try and adjust the low and high on the carb to see if it helps. CCW will richen the fuel mixture and what you have is a lean condition.
    blacksmith and dougand3 like this.
  3. brenndatomu
    Fuel line cracked, sucking air...
  4. dougand3
    dougand3
    North Alabama
    If carb/fuel line repair doesn't fix it, pull muffler and look at piston, ring, intake wall. Pull plug and look at exhaust wall. Another possibility is some scoring or ring wear and lower compression when hot.
    MightyWhitey and blacksmith like this.
  5. RCBS
    RCBS
    Over here
    Clogged fuel filter? Have you been running that machine on the regular, or has it been sitting?
    blacksmith likes this.
  6. blujacket
    blujacket
    Kettering, OH
    check spark arrestor screen, pull it and torch it
    BuckthornBonnie likes this.
  7. HDRock
    Put a little Sea-foam in tank , run it for a bit , might do the trick , if not ,go from there.
    It's surprising what a little Sea-foam will do
  8. SCOTTY1848
    SCOTTY1848 Banned
    Up State NY
    Torch the whole thing ,its a pull-on pro
    MightyWhitey likes this.
