Water Pipes ????
Discussion in 'Everything Else (off topic)' started by MightyWhitey, Jan 10, 2015.
  1. MightyWhitey
    MightyWhitey
    For those of y'all that "trickle" water to keep pipes from freezing; is there a "certain" amount of water that needs to flow to prevent freezing???
    Thanks!!
    wildwest and Well Seasoned like this.
  2. milleo
    milleo
    Maine
    If I was you I would not bank the stove when its really gonna get cold at night and let the furnace run some...I have never let my water run like that so I am no help, sorry....
  3. papadave
    Not sure MW, but my sis-in-law just had a problem with the pipes in her well pit starting to freeze.
    She lost water pressure, then no water.
    Put some insulation under the pit lid and plugged in a heat lamp. A few hours later, things loosened up enough she got things going.
    Stinny, eatonpcat, Chvymn99 and 4 others like this.
  4. IHATEPROPANE
    IHATEPROPANE
    Just a slow drip works for me. But I guess it depends on how cold it gets.....
    Horkn, wildwest and Well Seasoned like this.
  5. milleo
    milleo
    Maine
    I have wireless indoor outdoor thermometer that reads under my trailer and a light bulb and if gonna get real cold or temp drops to much underneath I let the furnace run...
    Chvymn99, wildwest and Well Seasoned like this.
  6. Well Seasoned
    I keep the kitchen sink and sometimes the bathroom on a cigarette butt wide trickle total. Also open the cabinets to let warm air in. We had a pipe freeze once, but didnt burst, and a hairdryer defrosted it. Since then... we super insulated!
    papadave, Chvymn99 and wildwest like this.
  7. wildwest
    Wyoming high plains
    we ran the slowest drip we could get, in both faucets on exterior walls.
  8. MasterMech
    You could always run heat trace on a problematic area.
  9. Horkn
    My dad always told me that simply a dripping faucet will keep even a problematic pipe from freezing. A rental house we lived at had a shallow supply pipe and a dripping laundry faucet always kept the line from freezing even in really cold temps.
  10. Well Seasoned
    Our kitchen sink is our only real concern. Its on an outside wall that gets blasted with the wind. We had an issue with the hot water pipe at a bend years ago.
    My IS heats my home and wildwest like this.
  11. wildwest
    Wyoming high plains
    and we ran an electric oil filled heater in the crawlspace where our main line came in.
    My IS heats my home, Horkn and milleo like this.
  12. Well Seasoned
    Good idea....... we hung a desk lamp with a 40 watt bulb and insulated the walls where our pipe comes in. The lamp gets turned on when it drops into the teens. Better safe than sorry.
  13. yooperdave
    Last winter when all the cities/townships had trouble with freeze ups around here, they would authorize letting the water run without being charged for it. You would first have to take a meter reazding and then let her run.
    The amount of "trickle" that the municipalities would recommend was a stream of water no larger than the thickness of a pencil. Sounds kinda large, but it sure beats putting the township/city crews out there in below zero and overtime pay conditions!
  14. Gasifier
    smoke show said he ran a vent pipe with a small fan in it to redirect the heat from his clothes hamper that his underwear went in to the underside of where his water lines run. Never a problem since.
  15. KaptJaq
    KaptJaq
    Long Island, NY
    Slow trickles will sometimes freeze depending on the temperature of the source water. If your supply runs too close to the surface it may be at or just below freezing temps. The movement and pressure will keep it from freezing but, like a slow moving stream, it can eventually freeze.
    In a home with small pipes, usually 1.25" or less, a tiny trickle will prevent the bursting of the pipe as the water freezes. If your pipes are in good condition the minor expansion of the water will not generate enough lateral pressure to bust the pipe. The expansion will be guided by the pipe along the length of the pipe compressing the water ahead of it. As the freeze moves the pressure in the liquid water will increase until it is powerful enough to burst the weakest piece of pipe. The slightest trickle will release that pressure and save the pipe. Think about it, if you have town water and your shut-off valve fails the plumber will freeze the supply line to stop the water flow so he can change the valve.
    KaptJaq
    Firebroad, Well Seasoned and wildwest like this.
  16. Well Seasoned
    Checked my lightbulb since its been on for a week now. Temps rising here a bit next week!
    (Gasifier - not to get off topic, but nice avatar. The pen is mightyer than the sword!)
    Chvymn99 and Gasifier like this.
  17. mattjm1017
    mattjm1017
    I run the sink out in the unheated laundry room at a trickle and the sink in the slightly heated master bathroom at the opposite end of the house at a trickle also so far no problems with frozen pipes.
    Well Seasoned likes this.
  18. TurboDiesel
    Insulation is your best defense.:yes:
    The hot water always freezes first, the pressure doesn't make a difference.
  19. smoke show
    smoke show
    Pittsfield, Wi
    Never, I repeat NEVER tell Gasifier a secret! :whistle:
    milleo, Stinny, mattjm1017 and 5 others like this.
  20. My IS heats my home
    My IS heats my home
    Albany, NH
    I can just imagine that the water departments will be busy when we get some warm temps.
