Wanted! Walbro HDA 196
Discussion in 'FHC Classifieds' started by bigfrank, Feb 13, 2020.
  1. bigfrank
    bigfrank
    NorCal
    For my Husqvarna 350
    The one I have I beliebe to be bad Internaly. Even a known good rebuildable would be fine.
    Thanks all...
    M2theB, JB Sawman and J. Dirt like this.
  2. JB Sawman
    JB Sawman
    pennsylvania
    Hey big frank those saws had a lot of carb changes the hda196 has been changed up several times if you give me serial # of your saw i can change the number up for you and i can get a new one if you want JBsawman
    fox9988, farmer steve and M2theB like this.
  3. bigfrank
    bigfrank
    NorCal
    Thanks JB. I'll get the number and see what's up. Don't want to really buy a new one carb to put on this saw. Was hoping to find a good used one, but still may be able to do that if I know what the upgraded carb is. Thanks!
    JB Sawman likes this.
  4. JB Sawman
    JB Sawman
    pennsylvania
    No Problem I have no more used ones most of them were bad gas problems any way let me know JB
    bigfrank and eatonpcat like this.
  5. bigfrank
    bigfrank
    NorCal
    Here is the plate. One of the numbers isnt visible but in think you might be able to make it work. I think a new OEM carb is going to be a bit spendy to put on this saw. It's a fixer to flip but you xan.give me a price anyway. I know the aftermarket are hit and miss. Never used them on a 2 stroke but I know the 4 stroke carbs I have tried a couple of times didn't work that great. 20200214_151340.jpg
  6. JB Sawman
    JB Sawman
    pennsylvania
    I will check for you tomorrow but I think they are about 50.00 oem carb JB
  7. JB Sawman
    JB Sawman
    pennsylvania
    Hey big frank update carb Zama C3-EL18B on amazon for@15.00 JB
  8. bigfrank
    bigfrank
    NorCal
    You said there might be upgrades to that carb. Any model n UK numbers? Thanks again...
    Thanks JB, I'll check it out. Imwasmthinking that carb had a primer bulb, but if it is setup for on, I guess I could cap off that circuit?
  9. bigfrank
    bigfrank
    NorCal
    I now see they make them both ways. At $16, I guess I can give it a try. I got it on @Amazon, so if it doesn't work right, I can send it back. Thanks again!
    eatonpcat and JB Sawman like this.
  10. JB Sawman
    JB Sawman
    pennsylvania
    Good luck big frank it would have cost more to send you a used one and a rebuild kit seems crazy you can buy a new one for that glad I could help JB
    fox9988, bigfrank and eatonpcat like this.
  11. bigfrank
    bigfrank
    NorCal
    I know the aftermarket carbs can be hit or miss, but i guess it's worth a try. At least I can tune it with a tach and it's easier to tell if it's rich or lean on a 2 stroke. Thanks again for the help.
    eatonpcat likes this.
  12. david young
    david young
    I’ve had good luck with those specific carbs. That’s the way I would go.
