Using aluminum foil to cover BBQ grill grates? Any tips?
Discussion in 'The Smokehouse' started by don2222, Jul 6, 2023.
  1. don2222
    don2222
    Salem NH
    Hello
    To keep the propane gas grill grates cleaner, we tried wrapping tin foil over the top. We grilled lamb tips, changed the foil and grilled salmon.
    Do you use foil?
    Pic 1 - Grillee Lamb tips
    Pic 2 - changing foil - grates not to dirty
    Pic 3 - grilling salmon - foil helps hold on juices
    Pic 4 - put on the veggie racks to grill the vegs
    metalcuttr and Haftacut like this.
  2. don2222
    don2222
    Salem NH
    It is harder to keep the grates clean without covering them with tin foil.
    Here is the best way I found to clean the grill grates using a HF Soda Blaster.
    Cleaning Grill grates with Soda Blasting like the Statue of Liberty
    I did get some grill marks with the tin foil but it would be better without.
    Also for grill marks are cast iron grill grates better than Stainless Steel but harder to clean?
  3. eatonpcat
    I say why grill if you are gonna cover the grates!
  4. Haftacut
    Haftacut
    Rives Junction, MI
    Have a friend that uses the grill mats and swears by them. Cooks everything he normally would on a grill with them. I guess if the tin foil works for you, stick with it. Judging by your pics, I’d say they worked well!
    metalcuttr likes this.
  5. MikeInMa
    I bought some grill mats for those times I'm not grilling at home. Usually, a public picnic area where the grills are crusted with who knows what.
    At home, I have a Weber Genesis that's going on 35+ yrs. I got the stainless steel upgrade. They clean up just fine as it comes up to temp before cooking. There is a small warming rack that is not SS. When I plan to use it, I will cover in foil because of the rack being rusted.
    metalcuttr, eatonpcat and BHags like this.
  6. buzz-saw
    buzz-saw
    Ct.
    No foil here , I want the juices to burn when they hit the flames for flavor.
    Burn it hot , grill brush and let it rip.
    I think the only time I use foil is on the smoker for wrapping something like 3-2-1 ribs.
    metalcuttr, JD Guy, BHags and 3 others like this.
  7. fuelrod
    fuelrod
    Western Maine
    I would think at that point (covering the grates) that you might as well just use the broiler in the kitchen.
    Imho if it's not on a fire, or at least a propane flame, what's the point?
    Of course I'm a wood snob and haven't cooked outside with propane for 15+ years.
    Until my wood fire settles down, it's kissing my grates and cleaning them thoroughly, 5 seconds with a wire brush and we're cooking. :thumbs:
    metalcuttr, BHags, eatonpcat and 5 others like this.
  8. jrider
    jrider
    No foil here. Don’t see the point in grilling if you use foil.
    metalcuttr, BHags and eatonpcat like this.
  9. JD Guy
    JD Guy
    Upstate SC
    After many years of grilling the grates are seasoned “just right” and a quick wire brushing, bring up to sear temp and away we go!
    Softwood, BHags, jrider and 1 other person like this.
  10. woody5506
    woody5506
    Upstate NY
    Keeping the grates clean is easy with a wire brush, but the real mess of gas grills is all the crud that piles up inside them. Makes for a good fire when it eventually catches.
    JD Guy and BHags like this.
  11. eatonpcat
    I have had a few grease fires over the years!
    RCBS likes this.
  12. RCBS
    RCBS
    Over here
    This is my tip regarding foil and gas grills....if the electric is out and the stove don't work, don't be too hasty to throw a pound of bacon on foil over the grill. In my particular case I ended up with a pound of half cooked, half black-charred bacon after the grease fire lit up. Hindsight tells me that cooking it right on the cast iron grates would have yeilded better results. The foil allowed the grease to pool rather than burn off as it cooked. Not my proudest moment, but I wanted bacon.
    don2222, eatonpcat and fuelrod like this.
  13. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    There's ways around that...the bacon is better cooked on foil
    metalcuttr and eatonpcat like this.
  14. BHags
    BHags
    Massachusetts
    Use your cast iron fry pan on the grill. All problems solved.
  15. lukem
    I don't see any reason to cover grill grates with foil. Keeping my grill grates clean is way low on my list of priorities when it comes to cooking...I'd rather my food taste like it was grilled.
