Tomorrow............
Discussion in 'The Wood Pile' started by thewoodlands, Aug 7, 2015.
  1. thewoodlands
    thewoodlands
  2. Well Seasoned
    Its getting much more pleasant out to be working in the woods. Those tongs should work well. A decent sized eye bolt would work just as well (would take longer though) if you were bringing up rounds- hooking up to the winch. Looking forward to some :ithappened: when it all goes down............
  3. haveissues
    haveissues
    Hudson Valley
  4. thewoodlands
    thewoodlands
  5. thewoodlands
    thewoodlands
    It's perfect for working in the woods up here, we drop to 47 last night. It's time to take the 660 with me for this job.
  6. haveissues
    haveissues
    Hudson Valley
    If they don't, give the choker hook a try. $7 and a length of chain is a lot cheaper than tongs and it works.
    Eric VW, Horkn, clemsonfor and 2 others like this.
  7. thewoodlands
    thewoodlands
    I think for me to get them up the hill I'll need to cut them down to single rounds or a length that I could cut in half to make two rounds.
    I have chains so if I use them what would be the best way to wrap the round so I could pull or winch them up?
  8. haveissues
    haveissues
    Hudson Valley
    That choker hook is a slip hook. The harder you pull, the tighter it gets. It probably won't work well with just a length of chain. You pin it on the end of a 5 or 6 ft chain and make a loop with the hook.
  9. Gasifier
    Something else you could try in the future. I have also used a log dog that I learned about from Camp Inspector. Pound it in quickly with a hammer or back side of hatchet, hook a chain to it and pull away. When done just pound on it from one side and then the other to loosen it up. Here is a pic of one.
  10. thewoodlands
    thewoodlands
    If it wasn't for dealing with the top, I would've finished this today, also I needed a longer bar because for some stupid reason I went with a 18 & 20.
    The 28 inch bar will go up with me next time. I not sure on how much wood we'll get but our open areas should be full by late fall.
    One of the bigger rounds took off down the hill so I checked down in where I thought it would be, it's not there so I'll hunt for it this fall
  11. thewoodlands
    thewoodlands
    I did bring home one load of the smaller stuff.
  12. Well Seasoned
    Nice job Woody!:thumbs:
    That round you lost down the mountain must have been the same one that rolled into my yard! But fear not, its split and stacked already! Thanks!:handshake:
    Eric VW, Gark, gboutdoors and 7 others like this.
  13. Backwoods Savage
    That Rhino and a simple chain should do the job nicely for pulling those logs. I use a short 10' chain. Put a slip hook on one end and a grab hook on the other. Use the slip hook on the log, of course. I'd try cutting probably 4-6' logs and see what happens.
  14. thewoodlands
    thewoodlands
    U R welcome!
  15. thewoodlands
    thewoodlands
    I'm not sure how we'll do it but we'll get it done.
    Eric VW, gboutdoors, Horkn and 2 others like this.
  16. Gasifier
    Good work thewoodlands! Nice pics man!:yes:
    Eric VW, Horkn, Well Seasoned and 2 others like this.
  17. thewoodlands
    thewoodlands
    Backwoods Savage , I had a dream last night that some little redhead pulled those big azz rounds up the hill all by herself. :whistle:
  18. thewoodlands
    thewoodlands
    Thanks Gasifier , before I get going on the main trunk again, I'll clean the mess up at the top so that area is clear for some pulling up of the bigger rounds.
    I think we'll try pulling with the chains and the cables.
    Eric VW, gboutdoors, Horkn and 3 others like this.
  19. clemsonfor
    I was thinking and going to reccomend this same thing.
    I would take my saw and mark the lengths of 3-4 rounds then buck it and drag those longer pieces to flat loading area then buck the rest of the log up there and load it.
    Eric VW, Horkn and Backwoods Savage like this.
  20. Backwoods Savage
    I'll pass that idea along!
    Eric VW, Horkn and thewoodlands like this.
