Time for replacing the ceramics in the Wood Gun gasification boiler.
Discussion in 'OWB's and Gasification Boilers' started by Gasifier, Sep 26, 2019.
  1. Gasifier
    Through eight seasons with the boiler and getting ready for number nine. It’s time to replace the main ceramics in the burn chamber.
    Just after unwrapping them where I set them in the detached garage.
    69C2B0CE-0C11-402D-BE92-AEB4059ED1A1.jpeg 05208F20-3A88-43C4-9B44-435D22A83DF6.jpeg
    Moved them a couple at a time down into the basement. Also a box of replacement parts to go with. New blanket that goes under them, new plug for front end of main tube under the nozzle, new nozzle bricks, and some troweling mix for filling in any small gaps/spaces.
    Hopefully this weekend I will make time to get the boiler room cleaned up nice and get this job done. I’ll try to remember to take some pictures while completing the job.
  2. campinspecter
    campinspecter
    Could you lay a tape measure across one of the sections? It would be interesting to know how big they are and how much they weigh.
  3. brenndatomu
  4. Gasifier
    Here you are campinspector.
    About 7-3/4” Thickness
    40.4 lbs each for the full size ones. Six of them. Two half thickness for one end.
    The whole pallet with other goodies weighed in at 397lbs.
    Time to put some tunes on and clean up the boiler room this morning.
  5. campinspecter
    campinspecter
    Thanks for the pictures with the tape! Just a nice size for handling . :salute:
    Felter, Eric VW, NortheastAl and 3 others like this.
  6. Gasifier
    The project begins.....
    You can see the main ceramics were to the point of breaking away on both sides of the “bridging” bricks.
    I would say with eight seasons in it appears I got my use out of them.
    fuelrod, Need2Saw, Eric VW and 4 others like this.
  7. Canadian border VT
    Did you get the room clean??
  8. Gasifier
    Yes. Then I had to go to another issue that day. :picard:
    :dex:
  9. Gasifier
    The main tunnels in the old ceramics...
    You can see how the holes started to make it through from the main burn chamber above to the right and left tunnels. 9F4EB0DB-1CFA-445E-B977-3EBCC67EF7E9.jpeg 8F8B3733-3A42-4A24-B4A5-D434484BFEFF.jpeg
  10. Gasifier
  11. Gasifier
  12. Gasifier
  13. Gasifier
    31D4B163-226E-4640-BF54-B49B0011FDF5.jpeg 1B8A1FED-D2EA-4104-BFF2-0A0B306412C3.jpeg
  14. Gasifier
    Mostly cleaned out now. Time for a break. I have an appointment to go to. Hopefully back in an hour to start back up.
  15. lukem
    That's a long break you're taking. :whistle:;)
  16. Gasifier
    :DSo I’m at a stand still now. The blanket that goes under the new ceramics is missing a piece. I had to call AHS to tell them something was wrong. I couldn’t figure out how to make the three pieces of blanket fit right. So the tech had me measure all three pieces and said ya someone made a mistake. So they are sending me another piece. Should be here end of week.
  17. Eric VW
    Not that I have such a gasifier, but was wondering if pointing up those bubbles with some refractory would add life? Especially in the flame path....
    Perhaps you do that already Gasifier, just wondering out loud.
    campinspecter and brenndatomu like this.
  18. Gasifier
    This is the first time I’ve replaced the main ceramics. They gave me a small bucket of troweling material for filling in along the edges/gaps. I don’t know about the bubbles/holes. I could try to fill them after I get them all installed.
  19. lukem
    They'll fill with ash right quick. I wouldn't bother.
  20. Eric VW
    There’s an option.
