Stove fitting into everyday life??? First timer... pipe damper use ??
Discussion in 'Modern EPA Stoves and Fireplaces' started by makey98, Nov 11, 2018.
  1. makey98
    makey98
    Indiana
    Got my chimney repaired and the chase pan coated. Still have the original clay liner and was reinspected and deemed safe. Plan to use this winter and reevaluate if I want to put in a steel liner. But for now, I want to try this stove.
    Question 1: this stove is for supplement heat in a finished lower level of a split level house. Main heat is a electric heat pump. Should I just make small fires and then when I leave close the air supply? Do you wait for fire to be mostly burnt out before leaving? I do have the Wyze cam setup to monitor and plan on getting thermocouple setup as well. Do you leave your stove on all night? My wife is in an out of the house all day so I am trying to see how people manage reloading and extinguishing when leaving... newbie here and paranoid.
    Question 2: Also, my piping out of the stove has a damper about 2 feet over the stove and then an electrical blower. What is the proper way to use the damper? To create more draft if the draft is weak and then open once the fire gets going? Can’t find instructions on this. Thanks all!
    Chaz, Maina, Chvymn99 and 4 others like this.
  2. Warner
    Warner
    Not knowing what you have for a stove I’ll tell what we do. I usually get up early and stoke the stove let it get up to temp then close up the draft to my desired location then leave for the day. When I get home I stoke it again, then again before bed from November to April.
    Sounds like you may have a draft inducer on your pipe I have no experience wth that.
  3. papadave
    Not needed, as long as the setup is correctly installed. I still remember the first time (and a few times after as well) I left the house for an extended time with the stove burning. I was apprehensive. :hair::picard:
    If you know how the stove runs while you're there, it runs the same way when you aren't there (unless you're constantly fidgeting with it).
    I'd say you can make whatever kind of fire you want, then the heat pump will run accordingly.
    Same here.
    Chaz, Maina, fishingpol and 7 others like this.
  4. bushpilot
    bushpilot
    Eastern Washington
    Excellent reply here.
    Chaz, Maina, Chvymn99 and 5 others like this.
  5. makey98
    makey98
    Indiana
    45D3A446-E9E4-4F01-8CE5-47C4E2934E05.jpeg Here’s a pic.
    Chaz, Maina, Chvymn99 and 6 others like this.
  6. Warner
    Warner
    I think that box on the pipe is meant to put out more heat? I think they are generally looked at as a major cause of creasote. Extracting heat from the exhaust causing lower stack temps. Might wanna ditch it.
    Chaz, Maina, Mitch Newton and 8 others like this.
  7. Warner
    Warner
    papadave has had the best advice, learn how the stove runs while you are home then you will be more comfortable when you leave.
  8. Backwoods Savage
    makey98 your concerns pretty much follow the new burners so don't despair.
    The first thing I would highly recommend is to remove that silly blower assembly that is in the flue above the damper. That is one of the worst contraptions ever invented; well, at least if you don't like creosote. Those are a creosote machine; get rid of it.
    Now as for how to handle the fires. Just think about us guys who have only the wood stove for heat. We've been this way now for 40 years with no problems. Yes, we have a fire all night and a fire when we are away from the house. Remember that the fire in the wood stove is not much different than a fire in a gas or oil furnace. Yes, there is fire, but it is contained.
    What you need to do is to take the time to learn the stove. But first, what is your fuel like? That is even more important than the stove for if you have poor fuel, you'll have poor results with the stove.
    But take some time when you are home; perhaps a weekend when you might watch a game or just keep busy around the house but are there. Check on it occasionally. Learn what does what (just like the damper). Start with smaller fires, like perhaps 3 or 4 splits. Don't add until those are burned down and you have a nice coal bed before reloading. And btw, don't clean out all the ashes whenever you do clean them. Leave an inch or two in the bottom of the stove; it will help the fire and insulate the stove.
    Generally you will want the draft and damper full open to get the fire going. When it is time to calm things down, try doing it with just the draft control on the stove. Most times this will probably work very well and you won't have to use the damper. Sometimes in high winds the damper can be very helpful in toning things down by closing it at least part way. You'll learn how far by trial and success. Again, I would not use the damper if it is not needed but you have it there in case it is needed.
    By all means, fill the stove before you go to bed or are leaving. Have the thermostat set so that it will turn on if and when the stove does not throw enough heat. Quit worrying so much!!!!!!
    Good luck....and get rid of that creosote machine.
    moresnow, Chaz, Maina and 10 others like this.
  9. papadave
    What Dennis said. He used more words than I did, but most excellent advice, as usual.
    Now that I've seen the picture, I will completely agree.......get rid of that "heat reclaimer". It should be more aptly named "creosote maker".
    We have some friends that had one and it caused too many problems, so they removed it.
    Chaz, Backwoods Savage, Maina and 6 others like this.
  10. B.Brown
    B.Brown
    USA
    My dad had one of those on his stove pipe, it had a built in scraper that you pulled in and out to clean the tubs, i wasn't really that convinced that it helped much. But, he seemed to think it did, he bought it, so, if he was happy, that's all that mattered, lol. When you think about it, its more of a obstruction in the pipe than any thing, that's not good in my mind.
    Chaz, Backwoods Savage, Maina and 5 others like this.
  11. papadave
    Your mind is working correctly.:thumbs:
  12. saskwoodburner
    saskwoodburner
    We were a bit apprehensive when we first got a wood stove, to leave a fire going at night, or when we left. I reasoned that even if we burned only part time, there would be savings, and there sure was. After awhile though, you get to realize the fire isn't going to act or do any different than it did when you were around it for the last 12 hours. And as BackwoodsSavage says above, most people have a different device that has a hot fire in it too, it's just called a furnace and it's automated. As for air settings, I leave them just a touch more air when not around, and damper I'd just go half as far if I'm not around. I'd rather burn a bit more vigorous than have the stove stall and woof! multiple times before it settles in.
    Chaz, Backwoods Savage, Maina and 3 others like this.
  13. makey98
    makey98
    Indiana
    Thanks all. Bought some replacement pipe at rural king so I will take out the blower and go from there. Have some good dry wood and kindling ready and my supercedars came on saturday. Almost ready.!!! .. bit concerning I have had 3 different chimney companies come to give me estimates and recs on making this stove and fireplace operational and not one said to get rid of that blower.... what would I do without this place??!!!!
    This truly is the best forum for any topic on the internet. I have had lots of interests over the years and am on all kinds of forums. This one is the best by far. Everyone so helpful, friendly and really enjoy sharing information, pics, and thoughts with each other. All for the love of wood, chainsaws and stoves.. great place!
    Chaz, mat60, Backwoods Savage and 7 others like this.
  14. yooperdave
    Yup. But, the problem isn't gonna be in the tubes, its gonna be in the chimney.
    Look at it this way, the heat needed for venting the products of combustion is being lowered by the heat reclaimer....so now the gases in the flue are cooler, so now they will condense quicker, so now soot ash creosote can form more readily.
    makey98 get rid of it and plan on spending time with that stove and learning its personality....kinda like a new woman. no?
    I've always said a wood stove is like a woman where a man is like a gas stove.....:yes:
    moresnow, Chaz, mat60 and 7 others like this.
  15. papadave
    I won't be telling my wife she's a wood stove, whether it's a good analogy or not.
  16. yooperdave
    Yeah, good move.
    But the next time you get her good and hot, think of the wood stove and how you spend time getting that to the point of good and hot too! :cool:
    (Pics not required) :handshake:
    c hardy, Chaz, mat60 and 5 others like this.
  17. papadave
    I've got various responses, but I think it best to not share.:whistle:
  18. yooperdave
    :whistle:
    Chaz, mat60, Maina and 1 other person like this.
  19. blacktail
    blacktail
    PNW
    You'll get comfortable with the stove after some use. Eventually you won't think twice about leaving the stove to run unattended.
    brenndatomu, Chaz, mat60 and 3 others like this.
  20. Unhdsm
    Unhdsm
    Bradford, Vermont
    For a group dedicated to getting every last btu out of firewood
    As a group dedicated to getting every last BTU out of firewood, we all just collectively cringed.
    :jaw::emptywallet::coldone:
