Stihl 029 Super to 039
Discussion in 'Chainsaws and Power Equipment' started by M2theB, Jan 27, 2020.
  1. M2theB
    M2theB
    Central Massachusetts
    72604D4B-950A-4706-9C89-023A153FB727.jpeg F527472B-2058-4FAF-9CFC-38F96A6FE0CD.jpeg
    I hate to love working on these.
    This one was in the bucket and HL Supply had sale slant on this last fall.
    Hope it’s a good winter project.
    Camber, Mtnbikerfred, Horkn and 9 others like this.
  2. M2theB
    M2theB
    49402959-EEFA-4316-AA84-A286328A0CE8.jpeg CE32B5E2-793E-43F6-ABB2-371C80CB5839.jpeg
    There’s one issue to deal with.
    Looks like the fuel line Blue Tape failed, exposing the catheter.
    Camber, Horkn, Screwloose and 8 others like this.
  3. T.Jeff Veal
    My friend has one of the 029 Super, I ran it for several years. Really liked it. Going to make it the big bore 039? I like our 029 that huskihl did...
    Camber, Horkn, Screwloose and 6 others like this.
  4. M2theB
    M2theB
    Yes sir. Got the 039 kit.
    And open the muffler some
  5. T.Jeff Veal
    I think you will really like it. The Super seemed a good bit stronger than the orginal 029. Are you going to do any port work while you have it down? After Kevin did ours, it will pull the 25" bar. I just run 20" on it though.
    Horkn, Screwloose, XXL and 4 others like this.
  6. M2theB
    M2theB
    Unlikely
    I may tinker with widening the exhaust, but nothing in elevation
  7. T.Jeff Veal
    That's what I was talking about, the intake and exhaust.
    Horkn, Screwloose, XXL and 3 others like this.
  8. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    The super should be stronger than an typical 029. It has a larger bore. Not a lot bigger, but enough to feel.
    Interesting attempt at a fuel line fix there haha.
  9. M2theB
    M2theB
    55AF2C31-B6D4-4FF6-B1B2-0BD26A201D99.jpeg Almost broke down to the point I can start cleaning parts. Have to pop the cylinder back on and pull the clutch.
    These things a rubic's cube.
    MFMc., Horkn, Screwloose and 4 others like this.
  10. T.Jeff Veal
    Thats a great start.
    Horkn, Screwloose, XXL and 2 others like this.
  11. huskihl
    huskihl
    Widen the ex a little, widen and lower the intake a little, open the muffler, and a healthy timing advance and they’re actually quite a capable saw
  12. M2theB
    M2theB
    Healthy?
    10 degrees?
    Horkn, Screwloose, XXL and 1 other person like this.
  13. huskihl
    huskihl
    8-10. Maybe 12. They’re all different, being molded plastic. Start small and work up
  14. M2theB
    M2theB
    Saw is all broken down and parts cleaned to the where I can start thinking about the build.
    This is my first grind so I’m practicing on the old cylinder with a Dremel and a needle file
  15. M2theB
    M2theB
    3FB05DD9-E249-44F9-81A3-0803C5D67EAF.jpeg C6A2BD48-EE56-407D-9C78-4CEA3F6C116A.jpeg C65E33A3-EA7F-4B3B-855A-C22765A3F57C.jpeg
    Going to try to clean up the exhaust some more. But the grinding is done.
    PatrickNY, Smaug, Horkn and 2 others like this.
  16. T.Jeff Veal
    Horkn, Screwloose and M2theB like this.
  17. M2theB
    M2theB
    Going back together
    Letting the Yamabond set up.
    039 Warhawk p/c
    Caber 49 x 1.5 rings
    AM seals
    AM intake boot and impulse.
    Oem fuel line.
    Mtnbikerfred, T.Jeff Veal and Horkn like this.
  18. Horkn
    Nice work!
    Are you using the blue tape again on the fuel line?:rofl: :lol:
    M2theB and T.Jeff Veal like this.
  19. T.Jeff Veal
    Looking good
    Horkn and M2theB like this.
  20. M2theB
    M2theB
    Not re-using the same tape.
    That would be silly.:wacky:
    Horkn and T.Jeff Veal like this.
