Steam pot is leeching something?
Discussion in 'The Wood Pile' started by mywaynow, Nov 28, 2013.
  1. mywaynow
    mywaynow
    I use a commercial grade 16 quart pot as my steamer. I believe it is aluminum. The pot has developed some metalic beads on the lower surface and there are a dozen or so powdery spots in the same area. I clean them off and they reappear. Only thing other than water in the pot is white vinegar once in a while. What gives?
  2. JoeyD
    JoeyD
    Vinegar is acidic, maybe some type of corrosion? Could some type of electrolysis be happening?
    Post a picture.
  3. swags
    swags Moderator
    I used an aluminum pot last year like that and got the same thing. Probably just the water and what's in it. Also the aluminum got thin probably from continues heat developed a few pin holes and had to replace it this year. The pot I used was from my turkey fryer, so I won't be using that again.
  4. WeldrDave
    That is Calcium and mineral deposit's creating a basic electrolysis. The iron and minerals in your water is beginning to "EAT" the aluminum, the softest metal. Nothing you can do will stop it, just slow it down, and note, the more you clean it off, the more it will appear! It's like cleaning the green off of a copper pipe, "don't do it" thats the materials way of protection itself. Vinegar will only make it worse, it's an acid! Clean it good with soap and water, leave it alone. "trust me" metals are what I do for a living.
    basod, raybonz and swags like this.
  5. mywaynow
    mywaynow
    We have hard water here, so you are probably dead on Dave. Will this pot be ruined if I continue to use it as a steamer?
  6. WeldrDave
    Yup!;)…. but it will take some time, years….
  7. ansehnlich1
    ansehnlich1
    Ya, I use cast iron and it gets white flaky crusty stuff all over it, to the point that I can scrape a quarter cup of it off the bottom and sides every now and then.
    Interesting though adding vinegar. Any of you guys/gals know a way to keep that cast iron pot looking good?
  8. mattjm1017
    mattjm1017
    The only thing I do to any of my cast iron is use hot water and a brillo pad then a light coating of olive oil on the inside. As far as something like your talking for the stove top im not sure if you would want to oil it but I could be wrong.
  9. WeldrDave
    Not really, Cast iron, or any metal, steel, cast, aluminum etc… wants to return to its natural form, "hence oxidation". Rust never sleeps! cast will rust/oxidize very quickly unless you keep it filled with water "all" the time. Those cast steam pots look nastalgic but they won't last very long. If you want to have something that won't rust or oxidize, use stainless steel and even that will corrode in time.
    papadave likes this.
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    I agree the acid and minerals will attack the aluminum pot. I use a porcelain coated 6 qt. cast iron dutch oven sans cover and this works and looks great. They are on sale at Walmart right now. Be careful not to damage the porcelain coating, clean with baking soda to prevent scratches and this should last for a very long time. You can see this pot in my picture on the left <<<<<<
    Ray
    WeldrDave and milleo like this.
  11. WeldrDave
    Agree, porcelain is "super" for a steamer! My problem is, I can't keep from beating one up or chipping it .
  12. raybonz
    raybonz Moderator
    Carver, Mass.
    Yup you have to be careful for sure! I've had this pot a few years now and it still looks great :) Think we paid 30-40 dollars for it at Walmart. It is heavy and they are also great for cooking.
  13. raybonz
    raybonz Moderator
    Carver, Mass.
    http://www.walmart.com/search/searc..._ta=1&search_query=dutch ovens sale&_tt=dutch
    Ray
  14. papadave
    I won't use Aluminum for cooking or on the stove.
