Standing dead pine…good to go?
Discussion in 'The Wood Pile' started by grandgourmand, Dec 13, 2021.
  1. grandgourmand
    grandgourmand
    Ontario
    I’ve a fair and of threads debating the dryness of standing dead. Mostly oak-related. And most concluding that just because it’s standing dead doesn’t mean dry and good to burn
    I don’t have a good supply of wood at my place in the country. But I do have a couple standing dead white pine. No needles, bark peeling. Stuff that I’d burn camping without hesitation. Just more concerned with putting in the stove.
    thoughts? I have a moisture meter, but i think it’s defective. Says everything is sub-20% when i m fairly certain it’s not.
  2. Chazsbetterhalf
    Chazsbetterhalf
    You could always get another mm. Can pick them up fairly cheap. Then compare the two.
  3. billb3
    It usually takes 3 months or so for the needles to turn brown and fall off.
    I've put a moisture meter to bark falling off and it's been under 20%. Smaller rounds that might be split in half up to in four.
    The centers/heartwood of large rounds, especially lower on the trunk might still be a bit on the high side moisture content. Pine gets fairly lightweight when it is well seasoned. Handle enough of it and you can tell by the weight. They dry out the rest of the way pretty quick when split though.
    I'd process into three piles, top of the trees, middles of the trees, bottoms of the tree and burn it in that order. That way the heartwood gets a chance to season better. If it is eastern white pine it finishes seasoning fairly quick once split. The "sap" is in the sapwood and dries up pretty quick once the tree is dead.
    If it is beetle killed it likely died from drying up and had a head start on the seasoning.
  4. brenndatomu
    My meter says to test it, put pins against palm and it should read in the low 30s...careful.
    Wouldn't surprise me if most of the branches and upper part of the trunk are ready to go.
  5. Sean
    Sean
    I've had lots of lodgepole pine, doug fir and larch read well below 20% when standing dead and all these coniferous are denser than white pine. If I can find some pics I'll share them. Keep in mind that moisture meters operate the most effectively when the wood is around 70f. Case in point. I dropped a nice big dead Doug fir on canadian thanks giving this year. It sat in rounds for a bit before I split it. It was rather coldish outside and my moisture meter was reading around 20% on a fresh split round. I took a split inside and warmed it up overnight and then took it back outside and resplit it. My meter jumped to 26%. I like the idea of sorting the tree into 3 sections.
  6. Scotty Overkill
    If it's still got bark on the main trunk, I'd say it may be a bit moist.
    Barkless, it'll probably be good to go.
    We took down a big dead spruce a month ago, the top 1/3 was ready to burn, as were many of the limbs. But the bottom 2/3 were too wet...I saved a whole pickup load of 3" diameter limbs for starter logs ...they were bone-dry. That's blacksmith up in the tree...
  7. grandgourmand
    grandgourmand
    Ontario
    OK thanks for all the advice. I figure it's dry, but you never know if someone's had a different experience. I'll do the three sections approach. I have at least two, probably more trees to target this weekend. Once I cut and split some, I'll know. White pine gets super light. This stuff will be more for ambiance than heat, but still.
  8. Scotty Overkill
    Hey its worth getting if you can use it. And the nice thing about it. Being it's dead, it'll season pretty quick once split.
  9. Mag Craft
    Mag Craft
    South East Wyoming
    I have cut alot of dead standing pine. Some of it checks out to be less than 20% but I have also had some that I could see the water squeeze out of it when split.
    The best thing to do is use a moisture meter. Takes away all the guess work. I have two so I can double check when in doubt.
  10. Backwoods Savage
    How about taking three splits and starting a fire even outdoors to see how it burns? Does it light off easy? If not, then it needs some time.
  11. grandgourmand
    grandgourmand
    Ontario
    Maybe cook some hot dogs while I'm at it. Win-win.
  12. Scotty Overkill
    Wait til it's down to coals....pine smoke isn't very tasty...lol
  13. Sean
    Sean
    We cook hot dogs and smokies on all types of coniferous out west as thats all we have in most cases. In fact I was at a bush party last week and had cheese smokies over it. Tasted great. In my smoker I would never use it of course.
