So... back to tarping the top stack of dried wood
Discussion in 'The Wood Pile' started by dotman17, May 1, 2020.
  1. dotman17
    dotman17
    Snohomish, Washington
    Do you do it? I had plenty of seasoned wood this last year that I couldn't use because it got soggy wet from the rains. I prefer to keep my yearly stash dry with a top tarp. Next year I will be sure. Yeah they are a pain. Yeah the wind kicks up. But yeah dry, dry wood burns easy and the best.
  2. Haftacut
    Haftacut
    Rives Junction, MI
    I’ve been wondering about what some of you guys think about this topic. I have stacked all indoors previously, and am going to be stacking some outside this year. At what point do you cover your stacks? Immediately, or do you leave them open through the summer? This is new to me and just wanting some opinions. Thanks:handshake:
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I top cover anytime rain is forecast. Other than that I leave it uncovered and let the sun and wind work on it. 2nd year it goes to the shed.
  4. Slocum
    Slocum
    North Central Indiana
    I try to cover as soon as I get it stacked.
  5. buZZsaw BRAD
    I use tarps, sheet plastic and metal. Hate them all. Sharp edges, holes, wind blowing them off. My stack space is very limited and i have nearly 50 cord of wood so its a constant challenge. Most of the stacks are in the shade too.
    My best stack has old sheets of OSB sloped with black pool plastic over it. Seems to work the best.
    But you are correct in dry is better.
  6. buZZsaw BRAD
    dont you have that nice quonset hut for stackingSlocum ?
  7. dahmer
    dahmer
    Ellwood City PA
    My stacking area is sloped so I use t-posts to stabilize the stacks, put a tennis ball on top of each post, then cover with tarps over the tennis balls and use my empty bar oil gallon jugs 3/4 filled with water to hold the tarps down. I keep 15 cords this way.
  8. dahmer
    dahmer
    Ellwood City PA
    Here’s a pic.
  9. brenndatomu
    I usually leave a new stack uncovered the first summer and then cover it before the fall rains start... and I am slowly switching over to EPDM rubber for covers...works as well or better than anything else I have tried...I was able to score some 0.060" which is the heavy duty stuff...stays put pretty well.
  10. theburtman
    theburtman
    I top tarp my wood as soon as it's stacked. My outside stacks get sun most of the day and the wind blows constantly here. Seems to work.
  11. Screwloose
    Screwloose
    I top cover immediately and I use canvas tarps.
  12. NH mountain man
    NH mountain man
    WMNF N.H.
    Same here, except I switched from tarps to sheets of plywood I get as scrap. I get a bunch of scrap 4" x 4" x 8' beams/posts and lay a couple on each sheet to hold them in place. I find it's much easier to clear the snow off of the plywood when you get feet of snow on top. Some of the stacks have side posts screwed to the pallets and the plywood is screwed to to the top rails on the posts. One of these days I'll have all my stacks like that. I have 15 cords.
  13. MikeInMa
    As some others do, I cover my racks at least one year before I know I'll be burning the wood. Mostly, with salvaged EPDM.
  14. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I love those plastic pallets. I’m still kicking myself for not getting more when I had a chance :headbang::headbang::headbang:
  15. Slocum
    Slocum
    Yes but in the process of emptying the Quonset hut. I’m wanting to poor concrete floor in it. I’ve been stacking outside and covering with conveyor belt that I’m getting from work, 42” wide belt covereds 2-16” side by side stacks really well. It’s HEAVY! I’ve only hade it blow off one time. I can’t get it on my stack without using my tractor. I’ll get a pic today
  16. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I put aside the shrink wrap from my boat the other day. I am going to see if I can cut it to length, then shrink it over the top of one of my stacks. If that works and holds up, I will work on getting most of them done that way.
  17. FatBoy85
    FatBoy85
    Washington State
    I need to give up this behavior because it’s quite maddening to get tarp covered wood and only get it blown off and wet. I’m leaving my wood uncovered right now as the sun helps get it dry. Washington rain seems to rain in sheets or blown rain. We’re lucky if we remember to get the wood covered sheds on the sides. Leaving those gapped a bit helps with circulation.
    Yes it is currently in the rainy season as well. But cover it after August more permanently, woodshed, garage(open ends or door though) I’ve recently bought metal roofing so this stuff will work quite well once it hits July so I may wait for a week of really warm weather in WA and cover it that way if I haven’t put up the woodshed yet or all the wood doesn’t fit in it.
  18. oldspark
    oldspark
    NW Iowa
    Topless here except for what i will need for the winter at hand, so some sets outside for 3 years. The Bur Oak i burnt that was cut green burnt like a dream at 15 to 17 percent.
  19. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I left white and red oak stacked and uncovered for 3 years. It doesnt get sun in the summer, but it gets some wind. It was still over 20% last summer, and not much better a few weeks ago when I moved it out into the sun and wind, single stacked and covered.
  20. FatBoy85
    FatBoy85
    Washington State
    After All I hear about oak absorbing water or not letting it go when split green, I decided not to chance my oak so much and cover it. The rain seems to help weather it a bit but overall it’s beating the ocean back with a broom.
