Simple pallet firewood rack
Discussion in 'The Wood Pile' started by Rowerwet, Nov 29, 2017.
  1. Rowerwet
    Rowerwet
    Seacoast NH/MA
    I had a pallet rack idea I never finished for the pallet challenge this past summer.
    It is still awkward to work with, so I kept letting the idea turn over in my mind.
    I think this is the final version.
    I get a bit more than a cord in each stack by laying three standard pallets in a row.
    I put bricks or stones under the front and rear edges of the pallets. 20171129_161228.jpg
    A vertical pallet sits on top of the end
    A short board is screwed to the bottom pallet securely.
    Then one screw is put into each vertical pallet near the bottom, allowing it to move .
  2. Rowerwet
    Rowerwet
    Seacoast NH/MA
    But another vertical pallet against the middle of the end pallet. Make the end pallet match the edge of this pallet.
    Drive screws through the side of the divider pallet into the vertical center member of the end pallet.
    Three screws minimum, mostly near the top.
    Drive diagonal screws through the bottom of each vertical member of the divider pallet down into the center member of the base pallet.
  3. Rowerwet
    Rowerwet
    Seacoast NH/MA
    This may not be a great idea, I got these 4x4 timbers free, so I attached it to the vertical members of the divider pallets, and hung the middle divider pallet from the 4x4.
    Drive a few more screws through the short boards and the end pallet
    My son and I made the rack and filled it in about 3 hours.
    The center of each pallet sags and counter acts the way a stack tends to shrink on the outside first.
    The divider pallets keep the stack locked in as it shrinks from seasoning
  4. MikeyB
    MikeyB
    Long Island NY
    Very cool, I have the same Makita Impact, great machine
  5. amateur cutter
    That looks like it works just fine. Nicely done.
  6. billb3
    For really heavy green wood I put support under the middle rail too.
    I'm not too picky (any more) about all 9 supports touching - just there close enough if things start sagging.
    My next set up I'll try pressure treated ground contact 2x4 or 1x4 under the skid rails instead of bricks/blocks.
    LOL, I've leveled 4x4 on top of concrete blocks for skids but that's a lot of effort for off the ground. Overkill. Solid though. :D
    The wall down the center might help hold "roofs" in place when taking splits out during the Winter. I'm always wedging skids in after I take part of a row of splits out. Fun with a foot of wet slushy snow on top.
    Rowerwet, savemoney, LongShot and 2 others like this.
  7. 460magpro
    460magpro
    usa
  8. NH mountain man
    NH mountain man
    WMNF N.H.
    That should work for you Rowerwet , fun with pallets. I screwed everything on my pallet racks as well for easy replacement of " tired " pallets.
    savemoney, Rowerwet and WeldrDave like this.
  9. WeldrDave
    My very first wood rack was just like that! :cool: It worked well. Only downfall was the "termites" ate it apart in two years! :eek::picard: I see it's up on bricks and that may help, termites are ferocious little buggers down here! Nice job! :)
  10. Rowerwet
    Rowerwet
    Seacoast NH/MA
    These are mostly pallets I used for stacking before, termites aren't a real problem around here.
    I'm going to add steel roofing and make them a sort of wood shed
  11. WeldrDave
    Very Lucky! I live in a relativley sandy soil area near the shore, and any wood that lays on the ground for a period of time will get consumed "fast" by those B@ST@RD's. :headbang:
  12. weatherguy
    weatherguy
    central massachusetts
    Looks like my racks, they lasted 5-6 years before the bottom rotted, now I'm rethinking the idea. May do pallets again but I may make a PT bottom, with pallets on the sides.
    WeldrDave likes this.
  13. WeldrDave
    That works well, But I would do what you said and put 4" x 4" pressure treated down first, then them ont top. That would last a while! :cool: I like the whole pallet idea for air and circulation, not to mention they are free most of the time! :D
    All my wood is sitting on "plastic" pallets! It took me a few years to scrounge up them.
    BigPapi and weatherguy like this.
  14. Lucy
    Lucy
    Arkansas
    Thank you:thumbs::thumbs::thumbs: Great idea. That way you can stack on both sides. I know what my next one will look like:D
    WeldrDave and BigPapi like this.
  15. Lucy
    Lucy
    Arkansas
    Same here in Arkansas. I've sprayed termiticide under it. We'll see if that helps any.
  16. BigPapi
    BigPapi
    The hills of Western MA
    Nice rack! I use pallet racks also, but with diagonal supports. My floor pallets are the big oak monstrosities, two or three years on most and no sign of decay yet. Knock wood. Having terrible uploading a better picture, maybe try tomorrow.
    shack, crzybowhntr, Hammy and 2 others like this.
  17. Rowerwet
    Rowerwet
    Seacoast NH/MA
    I tried diagonal supports, but found that they get in the way.
    There really isn't much force on the end pallet pushing out, unless you have mostly rounds instead of splits.
    Only the last foot or so of the stack.
    BigPapi likes this.
  18. Rowerwet
    Rowerwet
    Seacoast NH/MA
    I had wood on 4x4s directly, the frost shifted them and my stacks fell over more than once.
    Putting pallets on 4x4s makes the stack too tall for my son to grab the top
  19. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Added 4x4s to the ends to attach the roof to
    Self tapping screws for steel roofing to anchor the ends.
    Each end has a lip to keep the water from running down the end pallets.
    I ran the dimensions through a cord calculator, each rack is 1.1 cords
    Maina, WoodPirate, savemoney and 9 others like this.
  20. BigPapi
    BigPapi
    Or if it's 8' deep and stacked to 7' high. :)
    Rowerwet likes this.
