Should this be replaced?
Discussion in 'Chainsaws and Power Equipment' started by 94BULLITT, Nov 1, 2017.
  1. 94BULLITT
    94BULLITT
    Frederick County, VA
    Do you think this cranks seal needs replaced? I was able to hear it leaking when I was vacuum testing the saw.
  2. Hoggwood
    Hoggwood
    Southern BC
    Looks like someone was struggling to remove that one?
    One thing is for certain. She will be a screamer if it runs. At least for 30 seconds or so.
  3. 94BULLITT
    94BULLITT
    The saw had been sitting for over a year. I got it running after a couple hours of owning it but it idled at about 6000 rpms. At least I know it runs and sounds good. I'm hoping to get both crank seals tomorrow (if they are in stock) then vacuum and pressure test again. I guess with it sitting the seal dried out and disintegrated.
    blacksmith, Horkn and CoreyB like this.
  4. CoreyB
    CoreyB
    South east iowa
    I am going to go out on a limb and say yes.
    Horkn and 94BULLITT like this.
  5. Hoggwood
    Hoggwood
    Southern BC
    I find some leaks are hard to find. I have resorted to removing ignition components and with the block offs in place, dunking the saw in a bin of water. Tell tale sign of bubble tracers lead right to the source.
    That one would be blowing bubbles like a Jacuzzi. Looks like you can see the garter spring in a couple of places.
  6. 94BULLITT
    94BULLITT
    It was very easy to hear. I've used an automotive evap tester before. It makes smoke so I can see the leak. Yes, the spring is visible.
  7. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Is that a crack above the pocket, or just the paint?
    Moparmyway likes this.
  8. 94BULLITT
    94BULLITT
    It is saw dust/ dirt.
    Fifelaker likes this.
  9. PA Dan
    PA Dan
    White Oak Pennsylvania
    Depends on who it's for...
  10. Scotty Overkill
    I just bought a vacuum/pressure tester off of Glock37 a few weeks back at the Thompsontown GTG.....can't wait to use it.
    Gonna do seals/bearing in my 064 in the coming weeks, I'll try it out before/after on that saw. ..
  11. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Luckily most leaks are confined to serviceable rubber items in two strokes. The oddball case crack, case gasket leak, etc. are usually the exceptions and can be tricky to find. If there’s an out -of-spec leak or noticeable running issue, replace as needed.
    Scotty— those p/v kits are nice. Since you’ll be into an 1122, be mindful of the pto bearing seat area for play and the fw case half for cracks... seen a few 064s with problems there.
  12. The Wood Wolverine
    Little rtv and run it! :smoke:
  13. 94BULLITT
    94BULLITT
    This is on an 064. The dealer did not have the flywheel side seal in stock, which is the one that is leaking. Both seals are around $35.
    Scotty Overkill, blacksmith and Horkn like this.
  14. Scotty Overkill
    Will do, brother....thanks for the heads-up! I'm hoping to delve into this thing sometime next week, I wanna get this 064 up and running for the winter so I can give Redfin my 461 to work some magic on......
  15. Mag Craft
    Mag Craft
    South East Wyoming
    The rubber part of the seal or the lip of the seal should be facing the inside of the crankcase and the outside should be metal. Your picture is strange looking. Did someone put that seal in backwards or am I missing something there.
    p61 western, mdavlee and Moparmyway like this.
  16. Moparmyway
    Moparmyway
    New York
    Thats what I suspect
  17. 94BULLITT
    94BULLITT
    The seal is in the right way. The picture may be deceiving.
    Horkn likes this.
  18. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Nice. I have a gutted 064 oiler you can borrow if you’re going to use heat to set the bearings. Heck, I have Mattyo’s case sleeves if you wanna try those, too.
    Scotty Overkill likes this.
  19. Scotty Overkill
    Might take you up on that offer
    BuckthornBonnie likes this.
  20. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    The AM seal kits for 660 may not include this fw side seal. Some do, some don’t. It may be the same size as 046 fw seals (not sure...). AM seals, in my opinion, are pretty good.
    Take care when installing fw seals into 064s. Most 064 fws have a deeper set that, if the seal isn’t far enough, would quickly jeopardize the seal. I use a socket, but this is a nice case for oem tools. You can use the flywheel to guage how far the seal should be.
    p61 western and 94BULLITT like this.
