Red vs white oak blocking
Discussion in 'Everything Else (off topic)' started by Greenstick, Sep 19, 2024.
  1. Greenstick
    Greenstick
    I found a source for some 6x6 and 8x8 oak for using as blocking. What is the better wood to use? Mostly for if we'd need to block up a tractor or plot combine. Does one splinter out or crack more under compression?
  2. FarmerJ
    FarmerJ
    Minnesota
    Doesn’t matter.
    The compressive strength is similar in both.
    all that the dot requirements were for load blocks.
    pretty sure John Deere shipped with oak blocks.
  3. walt
    walt
    north central ohio
    I would probably use white oak if I had the choice, more dense and doesn't split as easy
  4. RCBS
    RCBS
    Over here
    Whoak.
    T.Jeff Veal, Eric VW, JimBear and 7 others like this.
  5. Barcroftb
    Barcroftb
    The Mitten
    White oak will stand up to the weather much better.
  6. Warner
    Warner
    Go with what they used on the U.S.S Constitution, White Oak. Them fellers were smart.
    T.Jeff Veal, Eric VW, JimBear and 8 others like this.
  7. buZZsaw BRAD
    X2
    eatonpcat, T.Jeff Veal and Eric VW like this.
  8. T.Jeff Veal
  9. FarmerJ
    FarmerJ
    Minnesota
    Ash is a good choice even
    I had deck boards for the outriggers made out of elm.
