pushing the drolet
Discussion in 'Modern EPA Stoves and Fireplaces' started by yooperdave, Feb 3, 2015.
  1. yooperdave
    Since it was below zero this morning, and I've got the time for it, I decided to run the eldorado and warm up the basement some. 59f yesterday and currently 75f; after about 6 hours or running with no blower turned on.
    I am using willow for the fuel, I'll save the hardwood (maple-ash-yellow birch) for the more serious -0 temps.
    Still think i may sell the stove this spring/fall and get another englander, though.
  2. wildwest
    Wyoming high plains
    What do you have upstairs?
  3. yooperdave
    The upstairs and 1st floor is served by a forced air system. Nat gas which of course is served by the OWB (shudder). We will use the gas in Sep early Oct before we start the OWB and again once it is shut down in the spring. I also have two grilles cut into the R/A plenum (pre-filter) to help pull air from the basement and keep it more tempered even when the wood stove is not lit. Open stairwells on each level; basement 1st floor 2nd floor.
    Chvymn99, concretegrazer and wildwest like this.
  4. wildwest
    Wyoming high plains
    sounds like a nice setup :)
  5. MightyWhitey
    MightyWhitey
    More like Yooperian engineering.........................if there is such a thing!!!!:whistle::zip:
    Sam and wildwest like this.
  6. oldspark
    oldspark
    NW Iowa
    Bad bad Leroy Brown had an Eldorado too.:D:p
  7. splitoak
    splitoak
    jefferson co wv
    A custom at that:D
    wildwest and oldspark like this.
  8. WiscWoody
    WiscWoody
    NW Wisconsin
    If you see some of the snowmobiles up there you'll just know there is such a thing! :)
    Chvymn99, yooperdave and MightyWhitey like this.
