Ported 346xp/262xp shootout....sort of
Discussion in 'Chainsaws and Power Equipment' started by cory@owen, Jul 23, 2015.
  1. cory@owen
    cory@owen
    3 different 346xps and 2 262xps. The 346s are faster in this size wood. Honestly.... The 262s would pull 24" bar just fine. If your cutting 16"-18" wood, a ported 346xp is the ticket. I think they would even handle a 20" bar just fine. None of the saws are tuned through the roof, just work tunes. And of course, they all wear different chains. Not a scientific test, just fun with ported saws. All saws ported by mastermind.
    Hinerman, HDRock, Shawn Curry and 8 others like this.
  2. cnice_37
    cnice_37
    Sweet soundtrack! Are the 346xps all running 3/8" setups?
    HDRock and Chvymn99 like this.
  3. cory@owen
    cory@owen
    The first and third 346 have 3/8. The OE has .325
    HDRock, Shawn Curry and Cut4fun like this.
  4. SquareFile
    SquareFile
    somewhere
    :bug:
    Good on 346xp, especially OE with .325
    Bad for the 262xp following. :p
    Thanks for the videos
    Cut4fun likes this.
  5. Sunfish
    Sunfish
    Success Mo
  6. cory@owen
    cory@owen
    The 262xp has more grunt and is still better for bucking because of the torque. The 346 noodles a lot better. 262's clog up pretty bad noodling. In my mind, the 346 is more useful. It's lightweight and super strong for its size. The thing that is impressive about these 262's is torque. Maybe I'll try an eight pin rim on the 262 next time. That would be iteresting.
    262xp ported:
    HDRock, SAWMIKAZE, Chvymn99 and 2 others like this.
  7. SquareFile
    SquareFile
    somewhere
    Usually it takes a strong saw over 80cc to pull a 8 efficient.
    cgraham1 likes this.
  8. SquareFile
    SquareFile
    somewhere
    Does anyone know how a stock OE346xp with .325 compares to a stock 262xp with 3/8"? I've never owned a 262xp.
  9. Birddogtg
    Birddogtg
    Central ohio
    Noodling takes a lot of torque,there is no way a 50 cc will out noodle a 60 cc saw,if you want to noodle with any speed you need 75 cc or more
  10. cory@owen
    cory@owen
    346 does noodle better, not because it's stronger, but because it clears better......a lot better. The 346 has plenty of grunt to noodle fire wood size lengths. I usually use a dolmar 7900 for heavy duty noodling:D, but the 346 does fine when I need it to.
    SAWMIKAZE likes this.
  11. cus_deluxe
    cus_deluxe
    Northern Michigan
    tried an 8 pin w 20" on my 272xp and it didnt like it at all. very grabby...went back to 7 pin and it cant be stopped with same 20" bar.
    concretegrazer likes this.
  12. SAWMIKAZE
    SAWMIKAZE
    PGH
    I tried 8 with a 28" ony 2172 on some small wood on a job we did , these trees were allowed to be taken for firewood so i tried some combos..its fun with 8 in small wood but a no go in bigger stuff
    mdavlee, HDRock, Ronaldo and 2 others like this.
  13. cgraham1
    cgraham1
    Nor Cal
    I found the same thing on my MMWS 7900. It liked the 7-pin better. My MMWS 2188 will pull an 8-pin just fine, though.
  14. SAWMIKAZE
    SAWMIKAZE
    PGH
    Same saw with 7 and full skip
    Kg461, mdavlee, HDRock and 1 other person like this.
  15. mdavlee
    mdavlee
    I like an 8 pin for a hot 70cc saw and 28" bar. Just have to set the chain up right for it.
    Kg461 and SAWMIKAZE like this.
  16. SAWMIKAZE
    SAWMIKAZE
    PGH
    Wanna set one up for me big mike ?;)
    Hinerman and mdavlee like this.
  17. mdavlee
    mdavlee
    Chain or saw?:saw:
    Chvymn99, concretegrazer and cgraham1 like this.
