Pellet Grill Thermal Blanket?
Discussion in 'The Smokehouse' started by bobdog2o02, Dec 4, 2015.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Hey guys, I have an Englander Pellet Grill. I really love it after 1 whole summer but.... Its getting cold now and the huge firebox has a hard time coming up to tem and staying up to temp under 45 degrees OAT. Does anyone know where to buy, or have an idea of how to make a Thermal blanket for this thing?
    mike holton Im the guy from H e a r t h .com that asked a bunch of dumb questions about how many pellets it used, and how long to get up to temp, etc.. I really liked your attention to my questions and did buy one....
  2. Eric VW
    Don't know jack about pellet grills, but if you want a back door thermal blanket, get 2 inexpensive welding tarps(HF) and a ceramic fiber blanket(1/2" thick) and stitch it up! Yes? No?
    It would work like a boss, but not be weatherproof.
    $.02 offered....
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Thanks eric. Cheap is the way I would like to go on this so I allready was thinking this.... any idea if I'd need something special to sew it with?
    wildwest and Eric VW like this.
  4. Eric VW
    Hmmmmm....high temp thread on the cheap? A person with some time on their hands and a whole lot of intense ambition could unravel a graphite impregnated stove gasket... Definitely up to the job, as long as your not trying to stitch through a "canvas" type weld blanket. "Woolly" type weld blankets would be best for this pellet grill experimental blanket....
    I'm up to $.04:rofl: :lol:
    Horkn likes this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I'm just waiting for somebody to ask what kind of bed a pellet grill sleeps in.....
    Eric VW likes this.
  6. OhioStihl
    OhioStihl
    Southern Ohio
    I have been using a Welders blanket. It isn't stitched or anything. When it gets cold I just lay it over the top and keep the wind off of it.
    Horkn and Eric VW like this.
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    What grill are you using? If at all possible it would be nice to be able to see the thermometer in the front of the right side door.
  8. Nitrodave
    Nitrodave
    Grayling Mi.
    Just bring it inside where it's warm...:p
    Horkn likes this.
  9. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I actually toyed with putting it the attached garage and leaving the door 1/4 open...
  10. OhioStihl
    OhioStihl
    Southern Ohio
    Mine is a traeger. The inside temp gauge is on the top and the blanket covers it. The digital display on the side is still visible. I use meat thermometer most of the time and a welders blanket tossed over the top just works for my setup.
  11. OhioStihl
    OhioStihl
    Southern Ohio
    I will get pics if I can this weekend. Ribs and bacon orders have been placed. Trying to get it all done by Sunday.
  12. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Thanks man.
    Horkn, OhioStihl and Eric VW like this.
  13. S. Roche
    S. Roche
    Nebraska
    This is the same setup that I use. My thoughts are the insulation is a plus but just keeping the wind off my Traeger is the main thing.
    Horkn and OhioStihl like this.
  14. OhioStihl
    OhioStihl
    Southern Ohio
    QUOTE="bobdog2o02, post: 414685, member: 3078"]Thanks man.[/QUOTE]
    Here you go.
    Horkn and S. Roche like this.
  15. OhioStihl
    OhioStihl
    Southern Ohio
    I think it was around 30 degrees or so this morning. Once I put the bacon and ribs on I covered it up. It holds the set temp pretty well. After I was done playing with the smoker I went for a short ride in the fog. Very pretty out. I came home to the smell of the smoker in the cool air. It put me in a good mood this morning.
    Horkn, S. Roche and bobdog2o02 like this.
  16. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Thanks for that, I think I'll have to try this.
    Horkn likes this.
  17. Mr A
    Mr A
    I used to tie a few bats of rockwool insulation over my Brinkman barrel smoker. I was considering a pellet grill, not after seeing this thread. I hadn't considered cold weather or windy day use. I'll keep the kamado i was going to trade for a pellet.
    Horkn likes this.
  18. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I think the kama do would have the same problem, that's alot of ceramic mass to heat up when cold before you can use it.
    I love the pellet grill, nothing like setting the temp and forgetting about it for a few hours, and still having the great smoky flavor.
    Horkn likes this.
  19. Mr A
    Mr A
    Thee ceramic mass IS insulation, little heat loss. Just did an overnight cook, while I slept, two 8 pound pork shoulders. Took about 15 minutes to bring up to 225° F temp, 30°F outside temp.
    Temp was still 220° in the morning. There are automatic temperature controllers that can regulate cooker temps. but aren't really necessary, it does an excellent job on it's own. Best part is after a long slow cook, plenty of fuel left to open up the air vents, bring temperatures up to 700+ in minutes for a high heat self cleaning.
    Horkn likes this.
  20. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Hey, I have the same grill. I haven't noticed any problems holding temps in cold. Make sure your thermocouple is clean. I had just about every part replaced under warranty cause it wouldn't keep temp at times even when new.
    Had the main board replaced.
    Now it's golden.
    Horkn likes this.
