Myriad Up Date
Discussion in 'Modern EPA Stoves and Fireplaces' started by Huntindog1, Mar 4, 2014.
  1. Huntindog1
    Huntindog1
    South Central Indiana
    Been using the New Drolet Myriad stove for a while now.
    Ease of use , I rate very high.
    Ability to Radiate Heat , I rate very high.
    Ability to shut it down to very low levels could be better. It still puts out alot of heat at its lowest setting.
    Secondaries are very different than Tube stoves. When this stove is at its lowest setting and still flames on the wood its hard to see secondaries. A look at the flue outside shows the stove is only putting out a very light smoke which may just be moisture.
    The heavy 5/16" top plate means stove top temps dont change as fast as the heavy top plate stores some heat.
    Very capable heater for sure.
  2. jeff_t
    jeff_t
    SE MI
    So you would rate it a good buy? It was a good price, for sure.
    Pallet Pete likes this.
  3. Huntindog1
    Huntindog1
    Yes a good buy
  4. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Nice review, man. Any runaway issues with it?
  5. My IS heats my home
    My IS heats my home
    Albany, NH
    HD1, what kind of level temps are you getting at low settings??
  6. Huntindog1
    Huntindog1
    Good control you can shut the flames off with the air control.
    Seems like it likes to cruise about 700 with control lever out about 3/4" from fully closed with a full load of good seasoned hardwoods.
  7. Huntindog1
    Huntindog1
    I should explain me saying it could be better at low settings , I mean some stoves can be turned down lower and still maintain secondaries.
  8. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Nice... seems like a quality stove and I like the 3.1cuft firebox.
  9. Huntindog1
    Huntindog1
    I learned from emailing drolet that the baffle does have insulation.
